Is there a way via Emoncms.org to expand the number of requestable data points. I am looking to request say a days worth of data or even an hour?
I realise that this is limited to 3000 by default for user experience reasons etc but for development purposes, I am willing to put up with the time overhead.
If I request too many, the following message appears:
{“success”:false,“message”:“Request datapoint limit reached (3000), increase request interval or time range, requested datapoints = 17100”}
Hello @bez this limit is more to protect the server from overload and in turn the user experience of all users, rather than the experience of the user making the request as per say. I realise it can be frustrating.
That’s correct. But perhaps importantly, it’s not quite the same emonCMS. The locally hosted one - especially if you use the download for the emonPi/emonBase, is likely to have more facilities, the public web version at emoncms.org tends to lag behind somewhat.
Or, even simpler, you can buy a pre-loaded SD card from the shop, plug it in and put the power to the Raspberry Pi. It’ll be accessible as a URL on your LAN.
