EVSE running extremely slowly or not at all under IOS 15 on both iPad and iPhone. Continues to work correctly on iPad with earlier version of IOS. This applies using both Safari and Firefox.
EVSE firmware version 7.1.3.EU
WiFi Firmware version 2.9.0
Wired connection using Win 10 also working correctly
This is a known issue with the v2 firmware, we would recommend updating to the v4 firmware, unfortunately this needs an updated WiFi module (@glyn.hudson couldn’t find the WiFi module on the store, do you offer a pre-flashed upgrade?)
Alternatively, on the general navigation list on most pages:
Mouse over “EV Chargepoints (EVSE)”.
What looks like a pop-up help appears, but it isn’t, it’s a 1-item drop-down menu.
Click that, you’re at (3) above.
A similar thing happens with most of the items on that shop menu - the content of the “drop-down” is not the same as the content of the link from the main menu.
Thanks guys, I need to order one but the page says:
Please specify which OpenEVSE controller hardware you’re using when ordering so we can be sure to include the correct cable
