Just wondering, what is the format that the Time Left expects in EVSE?
Trying to get the time to full charge to work correctly:
This is the value coming in from the EV integration:
Not sure how it gets 33 minutes from that, maybe it expects a different format?
How are you supplying the vehicle info?
Mqtt from home assistant with these values:
So what format does the Time to full charge needs to be? I can template it into the correct value instead of sending it as is.
You have to provide seconds for time left.
