# ESP8266 WiFi power monitor
**URL:** <https://community.openenergymonitor.org/t/esp8266-wifi-power-monitor/1692>\
**Category:** IoTaWatt\
**Tags:** iotawatt\
**Created:** [26 September 2016 02:33 UTC](https://community.openenergymonitor.org/t/esp8266-wifi-power-monitor/1692 "2016-09-26T02:33:54Z")\
**Showing post:** 19
**Author:** ![overeasy](https://community.openenergymonitor.org/user_avatar/community.openenergymonitor.org/overeasy/32/7124_2.png) [@overeasy](https://community.openenergymonitor.org/u/overeasy)\
**Post date:** [18 October 2016 13:19 UTC](https://community.openenergymonitor.org/t/esp8266-wifi-power-monitor/1692/19 "2016-10-18T13:19:04Z")
> [@dBC](#):
> Have you calculated the source impedance of your analog signals? The MCP3004/3008 datasheet goes into a fair bit of detail of what’s need at various clock speeds, but it looks like at 2MHz you need a fairly low impedance source. I’m wondering if some of your apparent phase shift might be caused by the sample-and-hold cap not being given sufficient time to charge?
Revisiting this question from a few weeks ago, there have been some new developments. I’m actually running the MCP3008s at 4MHz now, and as you point out, the sample-and-hold (S&H) cap needs a really low impedance source to work at that speed under “normal” conditions.
Even with 10K voltage dividers, I had quite a bit of sag running at 2Mhz. I came upon a software solution…
The datasheet explains that the S&H period is defined by the rising and falling edges of two specific CLK cycles in the SPI transaction. In another section, the datasheet recommends a methodology to program the SPI transaction when using a MCU where the transaction has to be in byte (8 bit) multiples. In that scenario, the S&H defining clock cycles are embedded in one of those bytes. You see where I’m going with this…
The actual SPI transaction is 17 bits. In a 24 bit stream, it is defined as the first “one” bit (the start bit) and the 16 bits that follow. They suggest right aligning the transaction, padding with seven leading zeros and the start bit in the first byte. You can shift the whole transaction left 4 bits so that the S&H period is defined by two cycles that straddle the first and second bytes. If you then separate the sending of those bytes, you can effectively make the S&H period any length you please. In my case, the natural latency between sending one and then two bytes seems to be enough to satisfy the S&H cap with my higher input impedance.
_[View the full topic](https://community.openenergymonitor.org/t/esp8266-wifi-power-monitor/1692)._
