Errors showing in exportbackup.log
Hi
I was carrying out a backup after some changes this afternoon.
I see some errors in the logfile regarding some missing files. This is at the start of the logfile which has usually scrolled away before I see it, so they may have been there for a while. The backup appear to complete without issue, I’ve actually used a backup for a transfer to a new SD card several times in the past.
Are these errors an issue?
=== Emoncms export start ===
Thu 24 Aug 17:47:34 BST 2023
Backup module version:
cat: /opt/emoncms/modules/backup/backup-module/module.json: No such file or directory
EUID: 1000
Reading /opt/emoncms/modules/backup/config.cfg....
Location of databases: /var/opt/emoncms
Location of emonhub.conf: /etc/emonhub
Location of Emoncms: /var/www/emoncms
Backup destination: /var/opt/emoncms/backup
emoncms backup module location /var/www/emoncms/Modules/backup
Image version: emonSD-10Nov22
-- adding /var/opt/emoncms/backup/emoncms.sql to archive --
tar: Removing leading `/' from member names
-- adding /etc/emonhub/emonhub.conf to archive --
tar: Removing leading `/' from hard link targets
-- adding /var/www/emoncms/settings.ini to archive --
no file /var/www/emoncms/settings.php
-- adding /var/opt/emoncms/phpfina to archive --
phpfina/
Mike
