At the start of this thread I mentioned I was wanting to upgrade to Java 8 and had been using guidance at the link I’d indicated to achieve this. In hindsight it would appear I already had Java 8 installed, just a lot earlier version than current.
The java: command not found message occurred after the commands to remove the old Java 7 files were invoked, which, since Java 7 was not probably present presumably removed some of the Java 8 links in the process. Anyhow, after returning the /tmp configuration to original via a reboot I tried re-installing Java 8 again from scratch. The installation went off without a hitch and the java -version command now results in:
pi@emonpi(rw):~$ java -version
java version “1.8.0_161”
Java™ SE Runtime Environment (build 1.8.0_161-b12)
Java HotSpot™ Client VM (build 25.161-b12, mixed mode)
So onwards - and many thanks for your guidance.
