Hello @Mark_Maritz this issue is now fixed, the cause was due to an incorrect min value feed setting, the software now catches the case where the feed does not exist but you may find your dashboard runs a bit quicker if you go through your dashboard and check that the dial settings are correct. There should be one referencing a feed that does not exist in the min value feed setting.
