Be a means of resetting each of the cumulative readings that are saved to EEPROM individually.
Also, a soft reset added to the options would also be useful.
You previously said that the new design meant that the EmonTX4 itself cannot detect if there is a CT fitted. I think there is an advantage to being able to disable the output of a sensor port in the Firmware. I suggest just simply store a value in the EEPROM, that says don’t output the data. This was done previously for the Temperature and Pulse sensors IIRC.
Sorry should have sent you a message, I fixed that pulse issue in v1.5.0. It’s worth updating to v1.5.3 though, quite a few fixes over the last week. The majority of units shipped this week are running v1.5.3.
Yes I think there could be a benefit to that, would certainly save bandwidth uploading to emoncms.org if nothing else. I started to add the user interface for that in the serial configuration web tool but have not yet implemented it at the firmware level.
The minimum could be just a reduction in serial data printed. A more complex implementation might save on sampling those channels - though that would be one for Robert and I to discuss (I know Robert is very busy with other things for now so might be best to come back to the practicalities of that at a more convenient time)
