Hi All
First of all, thanks for creating some great products. I built a EVSE last year, and it’s been running well.
I’m looking on expanding the system, and I’ve a couple of questions before I place an order for some gear.
- I understand that the emonTX V4 will have an additional 6 Chanel expansion board. Is it possible to order the expansion board and wait for the firmware to be ready? (Want to save on freight, as it’s expensive to ship 1/2 across the globe.)
- Is there a difference between a normal Pi and a emon Base when using direct USB connection and no a RF connection?
- Is there anything stopping me from putting multiple turns through the CT. I have some circuits that only have about 5A max going through, so contemplating increasing the accuracy of the monitoring this way.
- I’m thinking of using the emonTX V4 to do some basic monitoring of my HWHP. With the recent posts about temp monitoring and CT reading will this be an issue with the 6 channel expansion board, or is it better to offload this work to the Pi from the get go?
Thanks again
Neil
