I’ve been using the Descrete Sampling Firmware on 2 x EMONTX’s for a couple of years now and have noticed the continuous sampling firmware is now the current version. Is this calibrated in the same way by changing the constants in the sketch before updating it, or is there an easier way?
I note the readme says
‘Serial configuration currently supports configuration of the RFM radio and current & voltage channels.’
can someone point me to the documentation for this as I can’t seem to find it. I will be running it via a serial connection to an ESP8266 running Tasmota in case its relevant which is what I currently do, and all I’d like to do with the RFM radio is disable it
