TrystanLea
(Trystan Lea)
33
Hello @boydo, I have updated the firmware to @Robert.Wall’s latest that supports apparent power only mode, its available here GitHub - openenergymonitor/EmonTxV3CM: EmonTxV3 Continuous Monitoring Firmware (Default shipped EmonTxV3 firmware) or if you have an up to date emonPi/emonBase you can flash the firmware directly from the base station. That will make it possible to use the EmonTx without an AC-AC adaptor, but with USB power for the ESP8266 adapters (if that’s the route that you are taking).
