I previously had an emonTX setup with one DS18B20 (for upper tank temp) all working fine and logging to a local emonCMS (via emonBase). I would like to capture 3 more temps (lower tank, ASHP inlet and ASHP outlet) so have added the terminal breakout. I have confirmed all 4 sensors are working but I cannot see T4 in emonCMS. I have readings for T1 T2 T3 - how do I see those extra temperatures, the breakout board suggests it can support 6 temperatures T1 to T6?
I was powering the emonTX by just the AC adaptor, found I needed to switch to the USB 5v which I have done and removed (for now) the AC adaptor. My USB adaptor is 2 Amp, I did start with a 1 Amp which was not enough juice!
I have tried restarting the emonBase but still the same temperature inputs T1, T2 and T3.
Setup -
emonBase - local emonCMS
emonTX - 4 x CT clamps, 4 x DS18B20 temp sensors
(all parts sourced from OpenEnergyMonitor shop)
