# emonTx connecting to arduino IDE using programmer
**URL:** <https://community.openenergymonitor.org/t/emontx-connecting-to-arduino-ide-using-programmer/17166>\
**Category:** Installation\
**Created:** [10 March 2021 18:47 UTC](https://community.openenergymonitor.org/t/emontx-connecting-to-arduino-ide-using-programmer/17166 "2021-03-10T18:47:49Z")\
**Showing post:** 72
**Post date:** [20 April 2021 12:52 UTC](https://community.openenergymonitor.org/t/emontx-connecting-to-arduino-ide-using-programmer/17166/72 "2021-04-20T12:52:37Z")
> [@rdc-Green](#):
> Unfortunately i only have one Ethernet connection across the two cupboards that the emonTxs are stored. So I think i’ll need at least 1x RF connection to the emonbase.
The other way to do it is use a USB TTL and plug both into the EmonTX - again there has been discussion about this method.
The drawback (IIRC) is that you need to bind a specific USB device to a specific port so after a reboot the inputs are not switched.
[edit]
Yes, look at this thread. [Using 3 No. EmonTX with EmonBase - #24 by AntiGrav](https://community.openenergymonitor.org/t/using-3-no-emontx-with-emonbase/16780/24)
_[View the full topic](https://community.openenergymonitor.org/t/emontx-connecting-to-arduino-ide-using-programmer/17166)._
