I’ve been using a jeelink and some jeenodes for quite a few years now. If I buy an emon tx, and assuming I set the correct channel, frequency etc., will I be able to read the values on the jeelink, without having to re flash it etc? It’s be a nice easy add for me if so.
Thanks.
Have you searched this and (probably more relevant) the old forums? I know JeeLink has been used with OEM kit, I’m just not sure of the details. But as we use JeeLib, I’d expect only minor problems if any.
Yes you will be able to receive the data on a JeeLink. EmonTx uses jeenode packet format and should be compatible.
