I’m trying to back up the firmware on my emonTx as per the docs at EmonTx V3.4 - OpenEnergyMonitor Wiki
Link to setting up Arduino IDE is dead but I have all that done. Command I am using, with OEM TTL adaptor, is:
avrdude -v -p atmega328p -c avrispmkII -P /dev/ttyUSB0 -U flash:r:test_intel.hex:i
Result is:
[email protected]:~/emonTx$ avrdude -v -p atmega328p -c avrispmkII -P /dev/ttyUSB0 -U flash:r:test_intel.hex:i
avrdude: Version 6.2
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/home/hpt/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : avrispmkII
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel AVR ISP mkII
Programmer Model: Unknown
Also tried with sudo but no joy. Anyone successfully backed up their firmware?
emonTx boots up with the following details and is running a serial only firmware:
“emonTx V3.4 Discrete Sampling V2.90”
I have scoured GitHub for a version 2.90 of the firmware but nothing is coming up. Anyone know where the sketch or hex is?
