andy_l
(Andy)
21
Thanks both for your kind words
Bill - You never know how these things will turn out until the hardware arrives, but itās a nice little enclosure and very solid once the lid is on. Iām not sure I would trust it at the bottom of a swimming pool like one of the previous posters, but thatās more about the threaded gland rather than the enclosure itself.
Eric - I never intended to compete with the āweather geeksā
just build something to survive the northern weather. There is a Davis VP2 a few miles from me, so should be able to get an idea of the accuracy. I am very limited as to placement of the solar shield, so this is likely to be the main factor.
Cheers,
Andy
Jon
(Jon Murphy)
22
Andy - excellent job! I like the compact install!
I did something similar but with a different sensor. I used an AM2302 (wired DHT22) temperature-humidity sensor.
picture from adafruit.com
I wrapped the sensor with thread seal tape called PTFE (teflon tape). So far so good since I half expected to destroy the sensor with the high humidity.
I had a few Doāh moments. My backyard has lots of bushes and flowers and trees. Not the best environment to get good readings. From what I have read since the sensor should be far away from plants, grass, & trees. And it should be mounted two meters above the ground. Mine was mounted on a 4 foot (1.2 meter) fence post in our garden - not good!
Here is a comparison between the emonTH in my backyard and the local airport readings. The temperature readings are fairly good (blue is the emonTH & yellow is the local airport). The humid readings are not so good (green is the emonTH and red is the airport).
HI Jon,
Hereās some info that might help to improve your RH readings: www.nws.noaa.gov/os/coop/standard.htm
If you want to read about it in detail, hereās another link: www.ofcm.gov/siting/text/e-chap2.htm
Overall, the doc at the second link is aimed at airports, but the sensor siting info is universally applicable.
Jon
(Jon Murphy)
24
Bill - thank you for the info - Iāll read thru it tonight!
Is there a list of official NWS sites in my area? Something I could use to compare my temp & humid readings??
YW! Happy to help.
Hereās a couple of resources for āobā data:
www.aviationweather.gov
Click and drag the map to the area you want the ob data for, then click the METAR button on the toolbar near the top of the screen. Select the ob data you want to see by checking / unchecking the boxes just below the map. Zoom controls are in the upper left corner of the map.
http://mesowest.utah.edu/cgi-bin/droman/mesomap.cgi?state=IL&rawsflag=3
Hovering on a station - the black dots - pops up the ob data. Clicking and draging works the same as on the Aviaton Weather page. Zoom controls are in the lower right corner of the map. Ob data displayed on the map, and the source of that data, can be selected from the pull-down menus on the left side of the screen.
Mouse wheel zooming works on both pages.
andy_l
(Andy)
26
Just a quick update, as I put the solar shield up over the weekend.
For comparison, I am using Node-RED to pull in Wunderground data from a Davis Vantage Vue which is close by:
OEM node in yellow and blue, Wunderground data in red and green. Overall it compares pretty well, certainly close enough for me given the constrained mounting location.
Cheers,
Andy
Nice. Looks like you nailed it!
Jon
(Jon Murphy)
28
Bill - forgot to tell you āthank youā for the two links. The mesowest link was the one that had the best info. I asked for the local NWS site because the data I get from Weather Underground (WU) is different. I started staring at the data when comparing WU data to my outside emonTH and noticed something odd. The WU temperature always increments/decrements by 1.8 degrees. It almost seems like WU is grabbing the NN:52 (8 minutes before the hour) METAR data and converting the temp from ĀŗC to ĀŗF. Not quite what I wanted!
Good to hear one of them worked for you.
Wow nice install @andy_l !
You might be interested in another approach posted by @johncantor involving adding some extra water resistance to the existing emonTH:
andy_l
(Andy)
31
Thanks Glyn
Good tip there from @johncantor. I did chuck in a silica gel bag before final assembly to try and keep any moisture at bay, but some of that semi-setting potting compound is probably a good idea long term.
luru
(Ari-Matti Husa)
32
Whichever enclosure you use, do remember to drill a drain hole to the underside of the box. Unless hermetically sealed, condensation will surely accumulate.
Please can i get your Arduino code !!
