emonSD next steps: filesystem & logrotate
For some time now we have used ext2 with a block size of 1024 for the emonSD data partition. Following research I did, documented here: Learn | OpenEnergyMonitor. The lower block size of 1024 resulted in ~half the disk write load compared to 4096. My tests for ext2 vs ext4 seemed inconclusive.
Does anyone with a more in depth understanding on ext2&4 filesystems have a view on this?
I was recording write load by monitoring ‘sectors written’ in /proc/diskstats. E.g from https://www.kernel.org/doc/Documentation/ABI/testing/procfs-diskstats
The /proc/diskstats file displays the I/O statistics
of block devices. Each line contains the following 14
fields:
1 - major number
2 - minor mumber
3 - device name
4 - reads completed successfully
5 - reads merged
6 - sectors read
7 - time spent reading (ms)
8 - writes completed
9 - writes merged
10 - sectors written
11 - time spent writing (ms)
12 - I/Os currently in progress
13 - time spent doing I/Os (ms)
14 - weighted time spent doing I/Os (ms)
Command to return ‘sectors written’ for given partition:
sudo awk '/mmcblk0p2/ {print $10}' /proc/diskstats
Which looks in fact like something we could usefully track over time in the emoncms admin interface.
I will setup further testing here to compare with my original tests linked above.
Anyone looked at f2fs? F2FS - Wikipedia
Thanks @Greebo, I haven’t looked at F2FS looks interesting and worth investigating.
I’ve been logging sector writes overnight, here are the results for the emonSD-30Oct18 image. Blue series is the data partition (ext2 filesystem blocksize: 1024), Yellow series is the OS partition (ext4 blocksize 4096)
The reading is sectors written in a 60s period.
192.6 sectors written per minute = 3.21 sectors/s
3.21 sectors/s x 512 bytes per sector = 1.6 kb/s
There are 59 active PHPFINA feeds being written to on the system, a mix of 60s and 10s intervals.
Here’s the script Im using to record the above:
<?php
// CRON ENTRY:
// * * * * * php /home/pi/track_diskstats.php > /dev/null 2>&1
$apikey = "";
$host = "http://localhost/emoncms";
$redis = new Redis();
$redis->connect("localhost");
// Retrieve last value from redis
$last_sectors_written2 = $redis->get("diskstats:sectorswritten:2");
// Fetch current value
$total_sectors_written2 = exec("sudo awk '/mmcblk0p2/ {print $10}' /proc/diskstats");
// Save current value to redis
$redis->set("diskstats:sectorswritten:2",$total_sectors_written2);
// Calculate difference
$sectors_written2 = $total_sectors_written2 - $last_sectors_written2;
$last_sectors_written3 = $redis->get("diskstats:sectorswritten:3");
$total_sectors_written3 = exec("sudo awk '/mmcblk0p3/ {print $10}' /proc/diskstats");
$redis->set("diskstats:sectorswritten:3",$total_sectors_written3);
$sectors_written3 = $total_sectors_written3 - $last_sectors_written3;
// Send to emoncms
file_get_contents("$host/input/post?node=diskstats&data=totalsectorswritten2:$total_sectors_written2$
The same test running on the pi with installation based on the build script on a stock raspbian stretch with everything on an ext4 partition with block size 4096 and only 23 feeds, Im getting 800 sectors per minute 6.7 kb/s (4x the ext2 block size 1024 system), Is it really that simple? block size is 4x that of the ext2 partition, even though number of feeds being written is less than half…
Edit: on the 2nd test here there are large spikes every hour. If you remove these spikes the write rate is ~450 sectors/minute or 3.75 kb/s, 3.75 kb/s / 1.6 kb/s = 2.34x larger write rate for 40% of the number of feeds.
What’s the reason for closing the files after writing every four bytes? Why not let the kernel buffer the I/O?
Im not 100% sure, it was a while back now when I did the more detailed research into the PHPFina feed engine design. It either had to do with not being able to read new data from the file when it was still open? or it was a result of the file potentially being written as part of a single apache2 instance resulting from a http post request. For most systems this case is not relevant any more as feed are written to by the feedwriter as part of a always running background process and so in theory files could be kept open.
Moving the /var/opt/emon/phpfina… folders to an ext2 partition with a blocksize of 1024
data partition (/var/opt/emon)  16.4 sectors/minute =  0.14 kb/s
OS partition                     489 sectors/minute =  4.08 kb/s
Something is causing significant write load on OS partition…
Did you see the thread on netdata? Netdata - great tool for reporting system status. It will break the writes down by application I think.
@TrystanLea
I was surprised at yr result and intrigued by Bill Thomson’s suggestion in a related thread re: sudo cat /proc/diskstats and so decided to try it …
diskstats does not provide very user friendly output - no averages - just totals since the last boot up …
fields:
1 - major number
2 - minor mumber
3 - device name
5 - reads merged
6 - sectors read
9 - writes merged
In my application, there are 5 instances of emonTx/RPi3 running the emonSD image Oct 2018 updated to 9.9.8 to monitor a large PV installation (3 phase) and I ran diskstats on …
  • Node 11 at the Inverter
  • Node 13 at the Grid Supply Meter
  • watchman - an ‘emoncms server’ (without an emonTx) on the local network just receiving data from the other nodes
    … and got the following results …
diskstats.pdf (400.2 KB)
Focussing just on sectors read & write and adjusting to per min values, in summary the results were …
Instance No. of Sensors No. of ‘active’ inputs via HTTP No. of Data Feed files created Partition Sectors Read per min Sectors Written per min Sectors Total per min Percent
Node 11 1 0 6 OS 111.5 6.4 117.8 81%
Data 6.6 21.8 28.4 19%
Node 13 4 0 23 OS 82.7 42.9 125.6 54%
Data 29.4 78.0 107.3 46%
watchman 0 9 13 OS 59.4 7.9 67.3 34%
Data 8.2 122.4 130.6 66%
My conclusions are …
  1. Re the OS partition - Unsurprisingly sectors written to are vey much less proportionately than sectors read tho’ this is very dependent on the number of sensors./feed files created.
  2. Re the Data partition - Unsurprisingly, sector writing is more prevalent than sector reading. And also unsurprisingly, this is very marked in the case of watchman which effectively just runs emoncms.
In retrospect, it’s beneficial that watchman runs the OS & Data partitions on a USB HDD. Tho’ that is based on my understanding that writing to an SDHC is more potentially ‘life shortening’ than reading from an SDHC ?
Actually, the totals are updated each time it runs. So if you do something like
watch sudo cat /proc/diskstats
you’ll see it update every 2 seconds. (the default update interval for the watch command)
Correct. Reading a flash memory device does no harm. Only writing causes it to “wear out.”
Thankyou for sharing your results @johnbanks , it will be good to compare and monitor this across many systems, to verify that we are getting consistent results.
Another useful tool for working out what is writing to disk is iotop:
sudo iotop -oa
-o only shows processes writing to disk
-a shows cumulative totals
I’ve been able to reduce the OS write load significantly by:
  • changing log2ram to RSYNC and then daily rather than hourly sync, I would like to look into this in more detail, I haven’t applied your modifications yet @pb66. By setting the sync to daily I have effectively turned this source of writes off in my tests. log2ram seems to be responsible for the large spikes seen in post 5 above.
  • Placing both /tmp and /var/tmp in a tmpfs as per emonSD-30Oct18 fstab configuration - this removed the baseline write load seen on the OS partition, 112 sectors/minute, 0.9 kb/s
Im now down to (on the build script based system):
OS partition                     6.4 sectors/minute =  0.05 kb/s
But does /var/log fill up as a result?
Not really surprising, but is that a problem?
I’d suggest that these optimisations (including the log2ram) are made optional within the install process so they can not be implemented by users not on flash memory.
With emonhub on log level warning & demandshaper turned off, the logs fill up much more slowly. Im going to provide better debug/warning level logging for both feedwriter and demandshaper to improve it further. I think I would personally like to have ‘warning’ as the default log level across the emon scripts with the option to set to ‘debug’ if there is an issue and ‘warning’ level is not enough.
I agree that making this all user configurable is a good idea.
Its a good question. If higher write rate is equal to lower SD card life span then making efforts to reduce write rate makes sense. How significant the difference is I dont know. The optimisations so far have reduced the OS partition write rate by 97%. It is of course a balance between functionality and reducing write rate. I think an hourly log2ram sync using RSYNC and the tmpfs changes for /tmp and /var/tmp may do most of the reduction, I will keep testing.
Here’s a screenshot of the output of iotop, it provides a useful indication of the processes writing to disk:
jbd2 being the journaling block device Journaling block device - Wikipedia
I do think there needs to be a more dynamic solution to the problem (and we risk moving off the thread title - perhaps another split) of the logs filling up.
I’d advocate something like the use of monit and the space usage test to trigger a log rotation if /var/log fills up.
Comparing iotop with proc/diskstats Im getting quite different results.
Test period 10:32 → 12:12 (6000 seconds)
System1:
OS: 3.1 sectors/minute x 512/60 = 0.0258 kb/s x 6000s = 155k (iotop: 72k, 0.5x)
data: 43.0 sectors/minute x 512/60 = 0.358 kb/s x 6000s = 2148k (iotop: 7.5M, 3.6x)
System2:
OS: 3.1 sectors/minute x 512/60 = 0.0258 kb/s x 6000s = 155k (iotop: 60k, 0.4x)
data: 16.7 sectors/minute  x 512/60 = 0.139 kb/s x 6000s = 834k (iotop: 3.4M, 4.2x)
iotop is reporting ~4x proc/diskstats for the ext2 (blocksize: 1024) data partition and under half for the ext4 (blocksize:4096) OS
any ideas?
Just a point, as I have run into this issue, mounting the data partition differently to the OS makes expanding the SD Card really hard! Expanding Filesystem.
What is the rationale for mounting the data partition separately? Are there really any significant gains to be had in a world of such large SDCards for pennies?
The data partition is ext2 and uses a different block size, this is part of the low-write optimisations.
I do not think it is the financial cost of the sd card that is being considered here. It’s the loss of data and aggravation of rebuilding a new sdcard image each time it fails.
For the record, whilst i see the reduction in write levels reported and welcome any reduction in write levels. I was never totally sold on the idea of a 3rd partition on the same drive. I would prefer to see a small usb stick in place of the 3rd partition if it must be separated, that would lower the writes on the sdcard significantly further. I do however like with having a root /data folder for c ollating all my data and mysql etc for easy backup and or easier retrieval in the event of a fail.
Yes I get that, but does block size change the number of writes or just reduce the space used by small amounts of data? If the latter, when a 4Gb card was the largest you could get and was very expensive, I understand the optimization. Does this rationale still hold?
It is not just about the cost of the card, it is about the cost of the storage which has dramatically reduced since this design was implemented. But that is not mitigated by the smaller block size is it?
Loss of data is down to a poor backup regime - all storage devices are prone (at some point) to failing, even a USB stick.
Yes agreed but I presume you mean a logical folder rather than a physical partition? If all the data is grouped under any logical location it makes things far simpler (which is what DietPi does by default :smile:).
