Ryan_S
(Ryan S.)
1
Just noticed this. Was taking a look at my dashboard to see how much my monthly usage was on my OpenEVSE charger.
When I put my mouse over the month it is reporting the total at the next months.
Unless I am mistaking it’s operation.
Server Information
Server Information
Services
emonhub :- Active Running
emoncms_mqtt :- Active Running
feedwriter :- Active Running - sleep 300s 1626 feed points pending write
service-runner :- Active Running
emonPiLCD :- Inactive Dead
redis-server :- Active Running
mosquitto :- Active Running
demandshaper :- Active Running
Emoncms
Version :- low-write 10.1.13
Modules :- Administration | App v2.0.9 | Backup v2.1.7 | EmonHub Config v2.0.4 | Dashboard v2.0.5 | DemandShaper v1.1.0 | Device v2.0.3 | EventProcesses | Feed | Graph v2.0.6 | Input | Postprocess v2.1.2 | CoreProcess | Schedule | Network Setup v1.0.0 | sync | Time | User | Visualisation | WiFi v2.0.2
Git :-
Server
OS :- Linux 4.19.75-v7+
Host :- emonpi | emonpi | (192.168.1.24)
Date :- 2020-01-14 00:51:13 UTC
Uptime :- 00:51:13 up 59 days, 6:06, 0 users, load average: 0.10, 0.07, 0.08
Memory
RAM :- Used: 25.31%
Total :- 975.62 MB
Used :- 246.91 MB
Free :- 728.71 MB
Swap :- Used: 0.00%
Total :- 100 MB
Used :- 0 B
Free :- 100 MB
Write Load Period
Disk
/ :- Used: 46.93%
Total :- 3.92 GB
Used :- 1.84 GB
Free :- 1.89 GB
Write Load :- n/a
/boot :- Used: 20.55%
Total :- 252.05 MB
Used :- 51.79 MB
Free :- 200.26 MB
Write Load :- 0 B/s (59 days 5 hours 56 mins)
/var/opt/emoncms :- Used: 1.59%
Total :- 9.98 GB
Used :- 162.34 MB
Free :- 9.31 GB
Write Load :- n/a
/var/log :- Used: 37.59%
Total :- 50 MB
Used :- 18.8 MB
Free :- 31.2 MB
Write Load :- n/a
HTTP
Server :- Apache/2.4.38 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
Version :- 5.5.5-10.3.17-MariaDB-0+deb10u1
Host :- localhost:6379 (127.0.0.1)
Date :- 2020-01-14 00:51:12 (UTC 00:00)
Stats :- Uptime: 5119569 Threads: 16 Questions: 13098151 Slow queries: 0 Opens: 46 Flush tables: 1 Open tables: 40 Queries per second avg: 2.558
Redis
Version :-
Redis Server :- 5.0.3
PHP Redis :- 5.0.2
Size :- 446 keys (1.03M)
Uptime :- 59 days
MQTT Server
Version :- Mosquitto 1.5.7
Host :- localhost:1883 (127.0.0.1)
PHP
Version :- 7.3.9-1~deb10u1 (Zend Version 3.3.9)
Modules :- apache2handler | calendar v7.3.9-1~deb10u1 | Core v7.3.9-1~deb10u1 | ctype v7.3.9-1~deb10u1 | curl v7.3.9-1~deb10u1 | date v7.3.9-1~deb10u1 | dom v20031129 | exif v7.3.9-1~deb10u1 | fileinfo v7.3.9-1~deb10u1 | filter v7.3.9-1~deb10u1 | ftp v7.3.9-1~deb10u1 | gd v7.3.9-1~deb10u1 | gettext v7.3.9-1~deb10u1 | hash v7.3.9-1~deb10u1 | iconv v7.3.9-1~deb10u1 | json v1.7.0 | libxml v7.3.9-1~deb10u1 | mbstring v7.3.9-1~deb10u1 | mosquitto v0.4.0 | mysqli v7.3.9-1~deb10u1 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $ | openssl v7.3.9-1~deb10u1 | pcre v7.3.9-1~deb10u1 | PDO v7.3.9-1~deb10u1 | pdo_mysql v7.3.9-1~deb10u1 | Phar v7.3.9-1~deb10u1 | posix v7.3.9-1~deb10u1 | readline v7.3.9-1~deb10u1 | redis v5.0.2 | Reflection v7.3.9-1~deb10u1 | session v7.3.9-1~deb10u1 | shmop v7.3.9-1~deb10u1 | SimpleXML v7.3.9-1~deb10u1 | sockets v7.3.9-1~deb10u1 | sodium v7.3.9-1~deb10u1 | SPL v7.3.9-1~deb10u1 | standard v7.3.9-1~deb10u1 | sysvmsg v7.3.9-1~deb10u1 | sysvsem v7.3.9-1~deb10u1 | sysvshm v7.3.9-1~deb10u1 | tokenizer v7.3.9-1~deb10u1 | wddx v7.3.9-1~deb10u1 | xml v7.3.9-1~deb10u1 | xmlreader v7.3.9-1~deb10u1 | xmlwriter v7.3.9-1~deb10u1 | xsl v7.3.9-1~deb10u1 | Zend OPcache v7.3.9-1~deb10u1 | zlib v7.3.9-1~deb10u1
Pi
Model :- Raspberry Pi 3 Model B+ Rev 1.3 - 1GB (Sony UK)
Serial num. :- 3BD68E61
Temperature :- 53.69°C - 53.2°C
emonpiRelease :- emonSD-17Oct19
File-system :- read-only
Client Information
Client Information
HTTP
Browser :- Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36
Language :- en-US,en;q=0.9
Window
Screen
Hello @Ryan_S have you set your timezone on the My Account page? Testing here looks to be working ok.
Ryan_S
(Ryan S.)
4
I’ll double check that when I get home. I’m pretty sure I did, but maybe forgot when I reinstalled a couple months ago.
Ryan_S
(Ryan S.)
5
Took a look under my profile. Timezone is set correctly.
Thanks, ok, could you show all the options that you have set in the configuration panel for the widget?
What kind of source feed are you using? is it a cumulative kWh feed or daily kWh feed?
Are you using delta mode for the bar graph?
Ryan_S
(Ryan S.)
7
Figure a picture of the settings works.
Thanks @Ryan_S do you by any chance have a cumulative kWh feed of the OpenEVSE consumption (created using power_to_kwh rather than kWh/d)? This is now the recommended approach to generating daily, monthly etc graphs, see the guide here: Calculating Daily kWh - Guide | OpenEnergyMonitor
You can use the post process module (pre installed on the emonSD image) to create a cumulative kWh feed from historic power data if you have not already got a suitable feed.
Ryan_S
(Ryan S.)
9
I actually am creating mine from the amps output from OpenEVSE. I didn’t like the Wh output and just decided to calculate it from the amps multiplied by the house Voltage readings provided by IotaWatt.
Don’t mind the duplicate in there. One was a debugging item I was using and just left it.
That’s fine, looks like you have a Power to kWh feed as process number 8, if you use that with the delta mode in the bar graph it should give the best results: Calculating Daily kWh - Guide | OpenEnergyMonitor
Voltage multiplied by current yields Volt-Amps, (VA) i.e apparent power vice real power.
To get real power, you must take into account the power factor, as well. (V x I x PF)
If the load is resistive i.e. no reactive components, the Power factor will be 1
and Watts will be equal to VA.
Plus, if two different devices are being used, there’s no guarantee whatever that the two quantities are measured at the same instant - so there is another source of uncertainty.
Ryan_S
(Ryan S.)
13
Very true. Unfortunately I don’t believe the OpenEVSE reports the pf back, so I was just aiming for a general total energy consumption. (though I only pay rates based on real power) Unless of course the OpenEVSE total Wh report does include pf in it. If that’s the case, then I would consider seeing if I could parse out what the days energy usage was from it. I just couldn’t seem to find a way to get EmonCMS to do that.
