I’ve made a couple of updates to the EmonScripts install process and tested on latest RaspberryPi OS Desktop edition and a DigitalOcean VPS running Ubuntu 20.10 x64. Both now complete ok.
I’ve created an issue in the EmonScripts repository detailing both tests:
- DigitalOcean Ubuntu 20.10 x64 Build (2nd Nov 2022) OK!
- RaspberryPi OS 32bit desktop install (2nd Nov 2022) PROCESS UPDATE
The installation procedure has been updated to use php8.1 and compile and install the php redis and php mosquitto extensions correctly for php8.1. There’s also a new optional break point after the OS update and upgrade steps to allow a system reboot (recommended).
The latest RaspberryPi OS requires a slightly different initial setup process to run the right partition resize script. This step needs further review as I had to disable the new RaspberryPi OS firstboot script and that includes some steps that may still be a good idea to run.
