Hi
Just getting set up on emonSD-03may16 image. Unusually for historic reasons I use an mqtt broker on a different server.
I changed settings.php to my broker and very thing worked fine.
This morning I tried the update now command to make sure everything was up to date. A little later in the day I realised my mqtt inputs were not updating. On investigation I found settings.php pointing back to localhost. Presumably because of the update now command.
Regards
Ian
