Matt - here is another tool for debugging…
If you use node-red here is a flow that will monitor the various drives (e.g., /var/log, /home/pi/data), CPU load averages, temputure and memory.
Besides node-red you’ll need to install node-red-contrib-os for the drives and load averages.
My original flow saved the data via MQTT and sent alerts via Pushover. I modified (simplified?) this flow just to save the data to a log file. (feel free to ask for the original flow)
"id": "9930649a.efcee8",
"type": "function",
"z": "9692bb3e.836928",
"name": "",
"func": "if (!msg || !msg.payload) { return null; }\nvar now = new Date();\n/*if (typeof msg.payload === 'object')\n { msg.payload = \"\\n\" + JSON.stringify(msg.payload, null, 4) + \"\\n\";}*/\n\nif (typeof msg === 'object') { \n msg1 = msg;\n delete msg1._msgid; // drop the msg ID to save some room\n msg1.payload = \"\\nmsg : Object\\n\" + JSON.stringify(msg1, null, 4) + \"\\n\";\n }\n\nmsg.payload = now.toString() + \"\\t\" + now.valueOf() + \"\\t\" + msg1.payload;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 750,
"y": 160,
"wires": [
"e29a6c0f.5151c"
"id": "b1f61693.58f498",
"type": "comment",
"name": "emonPi CPU Monitors",
"info": "",
"x": 120,
"y": 40,
"wires": []
"id": "9e84ab4e.2ca66",
"type": "inject",
"name": "1 min",
"topic": "",
"payload": "",
"payloadType": "str",
"repeat": "60",
"crontab": "",
"once": false,
"x": 110,
"y": 140,
"wires": [
"85b2e630.3d142",
"b51b2b6c.596618",
"d61b2f06.bc18a8"
"id": "7ee2d8dd.dc3688",
"type": "Drives",
"name": "",
"x": 270,
"y": 100,
"wires": [
"8b8d23d2.62d3"
"id": "85b2e630.3d142",
"type": "Loadavg",
"name": "",
"x": 280,
"y": 140,
"wires": [
"6898e49b.f7e394"
"id": "6898e49b.f7e394",
"type": "function",
"name": "parse loadavg",
"func": "loadavgTopic = [ \"loadavg01min\", \"loadavg05min\", \"loadavg15min\" ];\n\nfor (i = 0; i < msg.payload.loadavg.length; i++) { \n msg2 = null; // msg2 for high load avg Alert\n var load = (msg.payload.loadavg[i]).toFixed(3);\n\n if (load >= 4.0) { // Send Alert?\n msg2 = {\"topic\":\"CPU Load Average Alert\"}; // msg2 for over high load Alert\n msg2.filename = \"/home/pi/data/emonCPU.log\";\n msg2.payload = loadavgTopic[i] + \" is too high at \";\n msg2.payload += load + \"\\n\";\n msg2.payload += JSON.stringify(msg.payload, null, 4);\n }\n\n msg1 = { payload : load}; // msg1 for mqtt load average\n msg1.topic = \"emon/emonpiCPU/\" + loadavgTopic[i];\n node.send([msg1,msg2]); // send for each load avg in for loop\n}\n\nvar pLoad = (msg.payload.loadavg[0] * 100 / 4).toFixed(1) ; // divide by 4 cores\nmsg1 = { payload : pLoad, topic : \"emon/emonpiCPU/pLoad\" };\nnode.send([msg1,null]); \n\nreturn null;\n",
"outputs": "2",
"noerr": 0,
"x": 520,
"y": 140,
"wires": [
"9930649a.efcee8"
"id": "b51b2b6c.596618",
"type": "exec",
"command": "cat /sys/class/thermal/thermal_zone0/temp",
"addpay": false,
"append": "",
"useSpawn": "",
"timer": "",
"name": "Get CPU Temp",
"x": 300,
"y": 200,
"wires": [
"5e7b01a4.ae101"
"id": "5e7b01a4.ae101",
"type": "function",
"name": "convert temp data",
"func": "msg.payload = (msg.payload / 1000).toFixed(1);\nmsg.topic = \"emon/emonpiCPU/tempC\";\nreturn msg;\n",
"outputs": 1,
"noerr": 0,
"x": 530,
"y": 200,
"wires": [
"9930649a.efcee8"
"id": "8b8d23d2.62d3",
"type": "function",
"name": "parse drives",
"func": "for (i = 0; i < msg.payload.length; i++) { \n msg2 = null; // msg2 for over high % capacity\n var mnt = msg.payload[i].mount;\n if (mnt == '/') { mnt = 'root'; }\n var pcap = Math.round(msg.payload[i].capacity * 100.00);\n if (pcap >= 80) {\n msg2 = {topic : \"emonPi Drive Alert\"}; // msg2 for over high % capacity\n msg2.filename = \"/home/pi/data/emonCPU.log\";\n msg2.payload = mnt + \" directory is at \";\n msg2.payload += pcap + \"% and is almost full (or full)\" + \"\\n\";\n msg2.payload += JSON.stringify(msg.payload[i], null, 4);\n\n msg2.priority = 0; // Normal Priority (0)\n if (pcap >= 90) { msg2.priority = 1;} // High Priority (1)\n if (pcap >= 98) { msg2.priority = 2;} // Emergency Priority (2)\n }\n \n var mnt1 = mnt.replace(/\\//, ''); // delete leading '/'\n var mnt2 = mnt1.replace(/\\//g, '-'); // replace remaining '/'\n\n msg1 = {payload : pcap}; // msg1 for mqtt drive % capacity\n msg1.topic = \"emon/emonpiCPU/\" + mnt2;\n\n node.send([msg1,msg2]); // send % for each drive in for loop\n}\nreturn null;\n",
"outputs": "2",
"noerr": 0,
"x": 510,
"y": 100,
"wires": [
"9930649a.efcee8"
"id": "60a8663a.576978",
"type": "inject",
"name": "15 min",
"topic": "",
"payload": "",
"repeat": "",
"crontab": "*/15 0-23 * * *",
"once": false,
"x": 120,
"y": 100,
"wires": [
"7ee2d8dd.dc3688"
"id": "d61b2f06.bc18a8",
"type": "exec",
"command": "free -m",
"addpay": false,
"append": "",
"useSpawn": "",
"timer": "",
"name": "Get Mem Usage",
"x": 300,
"y": 260,
"wires": [
"93a15f35.0574a"
"id": "93a15f35.0574a",
"type": "function",
"name": "get memory data",
"func": "if ((msg === null) || (!msg.payload)) { return null; }\n\nvar re = /^-\\/\\+.buffers\\/cache.*$/mg;\nvar contextMatch = msg.payload.match(re); // find line that starts with \"-/+ buffers/cache:\"\n// this equals [ \"-/+ buffers/cache: 475 497\" ]\n\nvar re2 = /^-\\/\\+.buffers\\/cache:\\s*/m; // find line that starts with \"-/+ buffers/cache:\"\nvar contextReplace = contextMatch[0].replace(re2, \"\"); // remove beginning \"-/+ buffers/cache: \"\n// this equals 475 497\n\nvar contextSplit = contextReplace.split(/\\s+/);\n\nvar used = contextSplit[0];\nvar available = contextSplit[1];\n\nmsg1 = { topic : \"emon/emonpiCPU/MEMfree\" }; // msg1 for mqtt memory data\nmsg1.payload = available;\nnode.send([msg1,null]);\n\nmsg1 = {};\nmsg1 = { topic : \"emon/emonpiCPU/MEMused\" };\nmsg1.payload = used;\nnode.send([msg1,null]);\n\nmsg1 = {};\nmsg1 = { topic : \"emon/emonpiCPU/MEMtotal\" };\nvar total = (+available) + (+used);\nmsg1.payload = (+total);\nnode.send([msg1,null]);\n\npUsed = ((+used) / (+total) * 100).toFixed(1);\n\nif (pUsed >= 70) { // Percent mem too high? Send alert\n msg2 = {\"topic\":\"Memory Alert\"}; // msg2 for high memory usage alert\n msg2.payload = \"Available \" + available + \" MB\\nUsed \" + used + \" MB\\n\";\n msg2.payload += \"Total \" + total + \" MB\\n\" + pUsed + \" % used\";\n msg2.filename = \"/home/pi/data/emonCPU.log\";\n msg2.priority = 0;\n if (pUsed >= 80) { msg2.priority = 1;} // High Priority (1)\n if (pUsed >= 90) { msg2.priority = 2;} // Emergency Priority (2)\n\n node.send([null,msg2]);\n}\n\nreturn;\n",
"outputs": "2",
"noerr": 0,
"x": 530,
"y": 260,
"wires": [
"9930649a.efcee8"
"id": "e29a6c0f.5151c",
"type": "file",
"name": "",
"filename": "/home/pi/data/emonCPU.log",
"appendNewline": true,
"createDir": true,
"overwriteFile": "false",
"x": 860,
"y": 240,
"wires": []
