I have a Emon Pi, working together with several dallas sensors and two emonTH stations.
When we left for holiday this summer, my girlfriend unplugged the internet router. However she did not unplug any other equipment that i have up and running.
This renders the EmonPi with no internet connection on the ethernet cable.
However, i have it set up so that it should log locally.
All the data from the holiday period is missing, but the EmonPi had power and was running all the time.
Even when i do get the router back up and running, there is no logging from the Pi.
After doing a hard reboot on the pi, it started logging again.
Is this a known issue? That the EmonPi stops logging when the ethernet is missing for a period? Or was this just a temporary hickup?
I am very interested to know, and i think that otherwise this should be looked into.
Maybe i have just configured the pi the wrong way, but all the data from before the holiday is there, and also after the holiday.
The Pi is also submitting the data to emoncms.org, with my user ID and API key.
I now came back to the unit, and logged in today from my local network.
Seems the same thing happened again.
For some reason, it will stop logging. And will not go on again until i make a hard reboot.
The unit is just base install, and sits with power all the time in my utility room. Uptil now i have had the unit for some years running with no problems what so ever. This problem started when i decided to swap the SD and put the newest version of EMONCMS on it.
Maybe there is a firmware or something on the board that crashes together with the new emonscms. But still the problem is very random it seems.
It responds, and i can log in with the IP that i have given the unit in the network, all sensors are connected but still its not logging.
Maybe it is something with the emonpi board?
The TH sensors are not connected either. I will look more into that.
Whn looking at the emoncms.org it seems data is there, but not on the local server (as shown previously) this is very strange. For some reason it is uploading data to the web, but not storing the same data on the device. Maybe something has happened with the configuration.
My local EMONCMS server does not register data for last 5 days, but logging in to emoncms.org shows the data in my emoncms account.
However one of the units is not logging at all. Maybe the battery is bad, but still that does not explain why the local emoncms server keeps dropping out.
Does anyone have clues on this?
Thanks!
(se attached images, these are screen shots from right now)
Yeh, I thought there may be fixes already. I’ve just done a big update of my emonpi for all things emoncms and emonhub related. So let’s see if I get it again! Had it a few times in the past year. It’s not very frequent. I always fail to notice it because my data also goes to a server I have on the public internet which is where I usually read from and the data makes it there.
I scoured the logs from the time it went off this time and nothing stood out.
