Hi, I hope someone can help me.
I’m trying to configure my new emonpi, but, whilst it sort of works, it doesn’t seem right.
It is logging readings, but they are way too low to be correct.
I have the following connection:
DC power supply.
AC power supply.
CT1 on neutral wire between meter and consumer unit.
Ethernet connection.
I have configured the input feeds via web interface, but the power reading is only one tenth of what I might expect (200w instead of 2kw).
I was wondering about the vrms reading. It reads around 38. Should that not be about 240?
Additionally, the push button on the emonpi unit is not very responsive. Most of the time it ignores me when I press it. Should it not easily cycle through the menus?
Any suggestions where I should look / things to try ?
