Hi All,
I just updated my emonpi via the emoncms web interface that is hosted on the emonpi.
This was a pre-built box that I brought from Open Energy Monitor themselves. No tampering has been done to the configuration in any way, the device has been offline for sometime as I was going to use it for a project but that died down.
I am able to access emoncms, but under nodes all are inactive (img attached)
EmonHub Log output:
2017-01-17 16:21:06,398 DEBUG RFM2Pi 1054 NEW FRAME : OK 8 0 0 0 0 0 0 0 0 162 90 223 0 184 11 184 11 184 11 184 11 184 11 1 0 0 0 (-56)
2017-01-17 16:21:06,403 DEBUG RFM2Pi 1054 Timestamp : 1484670066.4
2017-01-17 16:21:06,404 DEBUG RFM2Pi 1054 From Node : 8
2017-01-17 16:21:06,405 DEBUG RFM2Pi 1054 Values : [0, 0, 0, 0, 232.02, 22.3, 300, 300, 300, 300, 300, 1]
2017-01-17 16:21:06,407 DEBUG RFM2Pi 1054 RSSI : -56
2017-01-17 16:21:06,408 INFO MQTT Unexpected disconnection
2017-01-17 16:21:06,408 DEBUG RFM2Pi 1054 Sent to channel(start)' : ToEmonCMS
2017-01-17 16:21:06,410 DEBUG RFM2Pi 1054 adding frame to buffer => [1484670066.398014, 8, 0, 0, 0, 0, 232.02, 22.3, 300, 300, 300, 300, 300, 1, -56]
2017-01-17 16:21:06,411 DEBUG RFM2Pi 1054 Sent to channel(end)' : ToEmonCMS
2017-01-17 16:21:06,530 INFO MQTT Connecting to MQTT Server
2017-01-17 16:21:06,534 INFO MQTT Unexpected disconnection
2017-01-17 16:21:06,635 INFO MQTT Connecting to MQTT Server
2017-01-17 16:21:06,639 INFO MQTT Unexpected disconnection
2017-01-17 16:21:06,763 INFO MQTT Connecting to MQTT Server
2017-01-17 16:21:06,780 INFO MQTT Unexpected disconnection
2017-01-17 16:21:06,881 INFO MQTT Connecting to MQTT Server
2017-01-17 16:21:06,885 INFO MQTT Unexpected disconnection
2017-01-17 16:21:07,011 INFO MQTT Connecting to MQTT Server
2017-01-17 16:21:07,022 INFO MQTT Unexpected disconnection
2017-01-17 16:21:07,123 INFO MQTT Connecting to MQTT Server
2017-01-17 16:21:07,127 INFO MQTT Unexpected disconnection
2017-01-17 16:21:07,265 INFO MQTT Connecting to MQTT Server
2017-01-17 16:21:07,285 INFO MQTT Unexpected disconnection
2017-01-17 16:21:07,386 INFO MQTT Connecting to MQTT Server
2017-01-17 16:21:07,390 INFO MQTT Unexpected disconnection
2017-01-17 16:21:07,471 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 166 16 32 3 36 0 35 48 0 3 96 18 128 32 4 0 96 41 0 0 (-99)
2017-01-17 16:21:07,524 INFO MQTT Connecting to MQTT Server
2017-01-17 16:21:07,528 INFO MQTT Unexpected disconnection
2017-01-17 16:21:07,630 INFO MQTT Connecting to MQTT Server
2017-01-17 16:21:07,633 INFO MQTT Unexpected disconnection
EmonCMS Log output:
2017-1-17 16:14:19 MQTT INFO Reloading config
2017-1-17 16:14:25 MQTT INFO Reloading config
2017-1-17 16:14:31 MQTT INFO Reloading config
2017-1-17 16:14:37 MQTT INFO Reloading config
2017-1-17 16:14:43 MQTT INFO Reloading config
2017-1-17 16:14:49 MQTT INFO Reloading config
2017-1-17 16:14:53 FEEDWRITER INFO PHPTimeSeries bytes written: 0
2017-1-17 16:14:53 FEEDWRITER INFO PHPFina bytes written: 0
2017-1-17 16:14:55 MQTT INFO Reloading config
2017-1-17 16:15:01 MQTT INFO Reloading config
2017-1-17 16:15:07 MQTT INFO Reloading config
2017-1-17 16:15:13 MQTT INFO Reloading config
2017-1-17 16:15:19 MQTT INFO Reloading config
2017-1-17 16:15:25 MQTT INFO Reloading config
2017-1-17 16:15:31 MQTT INFO Reloading config
2017-1-17 16:15:37 MQTT INFO Reloading config
2017-1-17 16:15:43 MQTT INFO Reloading config
2017-1-17 16:15:49 MQTT INFO Reloading config
2017-1-17 16:15:53 FEEDWRITER INFO PHPTimeSeries bytes written: 0
2017-1-17 16:15:53 FEEDWRITER INFO PHPFina bytes written: 0
2017-1-17 16:15:55 MQTT INFO Reloading config
2017-1-17 16:16:01 MQTT INFO Reloading config
2017-1-17 16:16:07 MQTT INFO Reloading config
2017-1-17 16:16:13 MQTT INFO Reloading config
2017-1-17 16:16:19 MQTT INFO Reloading config
2017-1-17 16:16:25 MQTT INFO Reloading config
2017-1-17 16:16:31 MQTT INFO Reloading config
2017-1-17 16:16:37 MQTT INFO Reloading config
2017-1-17 16:16:43 MQTT INFO Reloading config
2017-1-17 16:16:49 MQTT INFO Reloading config
The RaspberryPi element seems to be boot looping, the LCD on the EmonPi just shows this, it has been on for about 20mins now with no change: âRaspberry Pi BootingâŚâ
Any help would be most appreciated.
Regards,
Charles.
