My emonpi has been working successfully with no intervention for over 1 year. Today I modified my “emoncms” dashboard to take in a recently added temp sensor connected to my EmonTX. All went well and the new dashboard is working fine. I then logged into my emonpi to have a look and noticed the “update” option which I then used. I went the box shortly after and the LCD screen on the emonPi shows
“Raspberry Pi
Booting…” and does not change. Pressing and holding the reset button has no effect. I removed the power for 30 seconds and restored it. It appears to reboot displaying V2.8.2 and then it returns to “rebooting” message. It has now been like this for 5 hours without change.
I can still log in to it but “Nodes” shows my usually active nodes (5 & 8) as inactive.
The very odd thing is that if I log in to EMONCMS.org my dashboard displays data and updates. I tested by turning on a grill and the sudden increase in power consumption was displayed.
I am now stuck - any suggestions please?
Below are a couple of extracts from the log files that still seem to be active. I hope that provides useful information.
Emoncms log
2017-2-17 14:36:14 FEEDWRITER INFO PHPTimeSeries bytes written: 0
2017-2-17 14:36:14 FEEDWRITER INFO PHPFina bytes written: 0
2017-2-17 14:36:20 MQTT INFO Reloading config
2017-2-17 14:36:26 MQTT INFO Reloading config
2017-2-17 14:36:32 MQTT INFO Reloading config
2017-2-17 14:36:38 MQTT INFO Reloading config
2017-2-17 14:36:44 MQTT INFO Reloading config
2017-2-17 14:36:50 MQTT INFO Reloading config
2017-2-17 14:36:56 MQTT INFO Reloading config
2017-2-17 14:37:02 MQTT INFO Reloading config
2017-2-17 14:37:08 MQTT INFO Reloading config
2017-2-17 14:37:14 MQTT INFO Reloading config
2017-2-17 14:37:14 FEEDWRITER INFO PHPTimeSeries bytes written: 0
2017-2-17 14:37:14 FEEDWRITER INFO PHPFina bytes written: 0
2017-2-17 14:37:20 MQTT INFO Reloading config
2017-2-17 14:37:26 MQTT INFO Reloading config
2017-2-17 14:37:32 MQTT INFO Reloading config
Emonhub log
2017-02-17 14:40:37,689 INFO MQTT Connecting to MQTT Server
2017-02-17 14:40:37,709 INFO MQTT Unexpected disconnection
2017-02-17 14:40:37,797 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 27 109 218 159 221 45 2 102 67 80 121 135 81 255 170 105 246 236 97 34 35 (-102)
2017-02-17 14:40:37,811 INFO MQTT Connecting to MQTT Server
2017-02-17 14:40:37,815 INFO MQTT Unexpected disconnection
2017-02-17 14:40:37,923 INFO MQTT Connecting to MQTT Server
2017-02-17 14:40:37,936 INFO MQTT Unexpected disconnection
2017-02-17 14:40:38,037 INFO MQTT Connecting to MQTT Server
2017-02-17 14:40:38,042 INFO MQTT Unexpected disconnection
2017-02-17 14:40:38,156 INFO MQTT Connecting to MQTT Server
2017-02-17 14:40:38,160 INFO MQTT Unexpected disconnection
2017-02-17 14:40:38,262 INFO MQTT Connecting to MQTT Server
2017-02-17 14:40:38,266 INFO MQTT Unexpected disconnection
2017-02-17 14:40:38,380 INFO MQTT Connecting to MQTT Server
2017-02-17 14:40:38,385 INFO MQTT Unexpected disconnection
2017-02-17 14:40:38,486 INFO MQTT Connecting to MQTT Server
2017-02-17 14:40:38,491 INFO MQTT Unexpected disconnection
2017-02-17 14:40:38,604 INFO MQTT Connecting to MQTT Server
2017-02-17 14:40:38,609 INFO MQTT Unexpected disconnection
2017-02-17 14:40:38,710 INFO MQTT Connecting to MQTT Server
2017-02-17 14:40:38,715 INFO MQTT Unexpected disconnection
2017-02-17 14:40:38,825 INFO MQTT Connecting to MQTT Server
2017-02-17 14:40:38,853 INFO MQTT Unexpected disconnection
2017-2-17 14:37:38 MQTT INFO Reloading config
