pi@emonpi:/opt/openenergymonitor/emonhub $ git diff
diff --git a/service/emonhub.service b/service/emonhub.service
index 216f391..4df17be 100644
--- a/service/emonhub.service
+++ b/service/emonhub.service
@@ -8,7 +8,7 @@ After=sysinit.target syslog.target local-fs.target
[Service]
User=emonhub
-PIDFile=/var/run/emonhub.pid
+PIDFile=/run/emonhub.pid
ExecStart=/usr/local/bin/emonhub/emonhub.py --config-file=/etc/emonhub/emonhub.conf --logfile=/var/log/emonhub/emonhub.log
PermissionsStartOnly=true
ExecStartPre=/bin/mkdir -p /var/log/emonhub/
pi@emonpi:/opt/openenergymonitor/emonhub $ git status
On branch stable
Your branch is behind 'origin/stable' by 148 commits, and can be fast-forwarded.
(use "git pull" to update your local branch)
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git checkout -- <file>..." to discard changes in working directory)
modified: service/emonhub.service
Untracked files:
(use "git add <file>..." to include in what will be committed)
src/src
no changes added to commit (use "git add" and/or "git commit -a")
I don’t know why the service file would have changed and those items added. If you cannot recollect doing so I suggest setting it back to the default and running an update from the UI.
to revert the changes
git checkout -- service/emonhub.service
then run an update from the UI (don’t just git pull).
