I am trying to update the emonpi but the /dev/root partion is full
pi@emonpi(rw):~$ df -BM
Filesystem 1M-blocks Used Available Use% Mounted on
/dev/root 3410M 3394M 0M 100% /
devtmpfs 481M 0M 481M 0% /dev
tmpfs 486M 0M 486M 0% /dev/shm
tmpfs 486M 13M 473M 3% /run
tmpfs 5M 1M 5M 1% /run/lock
tmpfs 486M 0M 486M 0% /sys/fs/cgroup
tmpfs 40M 0M 40M 0% /var/lib/openhab
tmpfs 1M 1M 1M 1% /var/lib/dhcpcd5
tmpfs 50M 7M 44M 13% /var/log
tmpfs 30M 1M 30M 1% /tmp
/dev/mmcblk0p1 60M 22M 39M 37% /boot
/dev/mmcblk0p3 25582M 2583M 21679M 11% /home/pi/data
Does anyone know to resize it or free up some space. I have already “ran sudo apt-get clean”
Server Information
Emoncms Version low-write 9.8.28 : 2018.01.27 Modules Administration : App v1.1.0 : Backup v1.1.2 : EmonHub Config v1.0.0 : Dashboard v1.1.1 : EventProcesses : Feed : Graph v1.2.0 : Input : postprocess : CoreProcess : Schedule : setup : Time : User : Visualisation : WiFi v1.0.0 Buffer loading… Writer Daemon is running with sleep 60s Server OS Linux 4.9.35-v7+ Host emonpi emonpi (127.0.1.1) Date 2018-04-22 09:19:26 BST Uptime 09:19:26 up 6:22, 2 users, load average: 0.75, 0.90, 0.62 HTTP Server Apache/2.4.10 (Raspbian) HTTP/1.1 CGI/1.1 80 MySQL Version 5.5.60-0+deb8u1 Host localhost (127.0.0.1) Date 2018-04-22 09:19:26 (UTC 01:00) Stats Uptime: 22942 Threads: 3 Questions: 23869 Slow queries: 1 Opens: 199 Flush tables: 1 Open tables: 51 Queries per second avg: 1.040 Redis Version 2.8.17 Host localhost:6379 (127.0.0.1) Size 533 keys (611.72K) Uptime 0 days MQTT Version 1.4.14 Host localhost:1883 (127.0.0.1) Pi CPU Temp 55.84°C Release emonSD-07Nov16 File-system Set root file-system temporarily to read-write, (default read-only) Memory RAM Used: 21.92% Total: 970.93 MB Used: 212.79 MB Free: 758.14 MB Disk Mount Stats / Used: 99.53% Total: 3.33 GB Used: 3.31 GB Free: 0 B /boot Used: 36.32% Total: 59.95 MB Used: 21.77 MB Free: 38.17 MB /home/pi/data Used: 10.10% Total: 24.98 GB Used: 2.52 GB Free: 21.17 GB PHP Version 5.6.33-0+deb8u1 (Zend Version 2.6.0) Modules apache2handler : bcmath : bz2 : calendar : Core v5.6.33-0+deb8u1 : ctype : curl : date v5.6.33-0+deb8u1 : dba : dio v0.0.4RC4 : dom v20031129 : ereg : exif v1.4 : fileinfo v1.0.5 : filter v0.11.0 : ftp : gettext : hash v1.0 : iconv : json v1.3.6 : libxml : mbstring : mcrypt : mhash : mosquitto v0.3.0 : mysql v1.0 : mysqli v0.1 : openssl : pcre : PDO v1.0.4dev : pdo_mysql v1.0.2 : Phar v2.0.2 : posix : readline v5.6.33-0+deb8u1 : redis v2.2.7 : Reflection : session : shmop : SimpleXML v0.1 : soap : sockets : SPL v0.2 : standard v5.6.33-0+deb8u1 : sysvmsg : sysvsem : sysvshm : tokenizer v0.1 : wddx : xml : xmlreader v0.1 : xmlwriter v0.1 : Zend OPcache v7.0.6-devFE : zip v1.12.5 : zlib v2.0 :
Client Information
HTTP Browser Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:52.0) Gecko/20100101 Firefox/52.0 Screen Resolution 1920 x 1080 Window Size 1903 x 948
