I’m trying to reach my emonpi data on local CMS, I had a clock problem but it has been solved by connecting emonpi with ethernet wire. It worked for an hour, we had inputs on the emoncms but then the emonpi started to upload and boot everytime. Now, the problem of boot/upload is away. An other problem occur, we can’t measure any power with emonpi, we only see 3 dash. And on the next screen it is printed “Connecting … please wait”. I don’t know how to fix this problem.
Ok,
I tried with an SD Card with the image available.
The card is a microsd 32GB/Go class 10 EMTEC brand.
I launched the emonpi with the new SD but it’s booting for 2 hours now…
I saw on the link you give that it may take a while but 2 hours seems a bit too long.
Do you have any idea to justify that time ?
I tried to reboot with the button on the emonpi. I saw that the raspberry is shutdown but not the screen.
Ok so you just downloaded the emon image. For me it is the emonSD-10Nov22 (Stable).
And then you add the SD Card into the emon ?
Did you try a new card? If the card is failing you must use a new one. In addition, if the same as the old card, you will have lost your setup unless you did a backup first.
