I am new with emoncms and try to get it working. I read the helps but i don’t understand how to configure it with emonlight.
I installed emonlight on de Raspberrypi image of emoncms.
The configfile of emonlight is:
sources = ({
# gpio pin for pulse signal reading
pin = 4;
# number of pulses equivalent to 1 kWh
pulses-per-kilowatt-hour = 1000;
pin = 6;
pin = 24;
pin = 25;
servers = ({
url = "http://192.168.0.251";
protocol = "emoncms";
map = ({
pin = 4;
node-id = 17;
api-key = "1";
pin = 6;
node-id = 17;
api-key = "2";
pin = 24;
node-id = 19;
api-key = "1";
pin = 25;
node-id = 19;
api-key = "2";
data-log = "/home/pi/data/emonlight/emonlight-data.log"
data-store = "/home/pi/data/emonlight/emonlight-data"
Running emonlight I get the following output:
pi@emonpi(rw):/$ sudo emonlight
read config from /root/.emonlight
log data to /home/pi/data/emonlight/emonlight-data.log
source 0: read last_time=2016-12-01 11:12:49, pulse count=2 from /home/pi/data/emonlight/emonlight-data
source 1: read last_time=2016-12-01 11:12:49, pulse count=68 from /home/pi/data/emonlight/emonlight-data
source 2: read last_time=1970-01-01 00:00:00, pulse count=0 from /home/pi/data/emonlight/emonlight-data
source 3: read last_time=1970-01-01 00:00:00, pulse count=0 from /home/pi/data/emonlight/emonlight-data
test buzzer pin -1
queued 2016-12-02 08:59:37.219355733: DT=78408.049179, P=3(1), Power=0.000000, Elapsed kWh=0.000000
queued 2016-12-02 08:59:35.644263565: DT=78405.981077, P=69(1), Power=0.000000, Elapsed kWh=0.000000
queued 2016-12-02 08:59:32.964023804: DT=1480669172.964024, P=1(1), Power=0.000000, Elapsed kWh=0.000000
queued 2016-12-02 08:59:33.718437700: DT=0.754164, P=2(5), Power=4773.498181, Elapsed kWh=0.002000
queued 2016-12-02 08:59:36.064829605: DT=2.345421, P=3(14), Power=1534.905730, Elapsed kWh=0.003000
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /input/bulk.json was not found on this server.</p>
<hr>
<address>Apache/2.4.10 (Raspbian) Server at 192.168.0.251 Port 80</address>
</body></html>
**send failed: HTTP response 404 : "http://192.168.0.251http://192.168.0.251/input/bulk.json?time=1480669173&apikey=1&data=[[0,19,4773.498181,0.002000,2],[1,19,1534.905730,0.003000,3],[3,19,1534.905730,0.003000,3]]"**
queued 2016-12-02 08:59:39.011924853: DT=2.946113, P=4(25), Power=1221.948950, Elapsed kWh=0.004000
queued 2016-12-02 08:59:41.634206161: DT=2.621362, P=5(34), Power=1373.331713, Elapsed kWh=0.005000
<html><head>
</head><body>
<h1>Not Found</h1>
<hr>
</body></html>
A yous can see I get an error (bold printed). May it is the way emoncms must be configured, I have no clue at all.
Can anyone point me to the right direction?
Thanks in advance
