emonHub ttyUSB0 USB serial adapter
Thank you for your reply Glyn.
The result of the git branch command is:
git branch
environ-master
master
  • stable
The result of the git pull command is:
git pull
Already up-to-date.
The emoncms version is 9.8.8:
Your answer give me a clue.
I change the branch to master and now is OK, the floating palette is correct and I can build the dashboard again.
An other question:
Can emonhub service to read simultaneous from two ports: e.g. AMA0 and USB0 ?
I can collect data from a couple of sensors with an USB to SERIAL adapter.
Thanks again.
I hope you don’t mind, I moved this question to a new topic.
The short answer is yes; you will just need to create a new entry in emonhub.conf in the [interfacers] section, you can edit this via the local Emoncms web interface.
There are two options depending on serial format:
1. EmonHubTx3eInterfacer
This interface handles name value key pairs e.g. name:value,name:value. This is the default serial output for latest emonTx V3 and emonTH FW.
Config example:
[interfacers]
### This interfacer manages the EmonTx3 ESP format serial
[[SerialTx3e]]
     Type = EmonHubTx3eInterfacer
      [[[init_settings]]]
           # Un-comment line below if using RS485 adapter
           #com_port = /dev/ttyRS485-0
           # default com port if using USB to UART adapter
           com_port= /dev/ttyUSB0
           com_baud = 115200
      [[[runtimesettings]]]
           pubchannels = ToEmonCMS,
2. EmonHubSerialInterface
This interfacer handles serial with space operators e.g NODEID VAR1 VAR2 VAR3
Config example:
[[SerialDirect]]
     Type = EmonHubSerialInterfacer
      [[[init_settings]]]
           com_port = /dev/ttyUSB0      # or /dev/ttyAMA0 or/dev/ttyACM0 etc
           com_baud = 9600              # to match the baud of the connected device
Hello,
I’m connecting an stm32 nucleo device directly to raspberry pi usb port. I’m trying to use the DirectSerial interface on the emonhub, but I get this log:
Am I missing some step???
thanks in advance
What does this command return?
ls -la /dev/{tty{AMA,S,USB},serial}*
I suspect an STM32 might use /dev/ttyACM0 rather than /dev/ttyUSB0 if it has an on-board USB serial adapter.
hello, I tried the command and got this:
pi@emonpi(rw):~$ ls -la /dev/{tty{AMA,S,USB},serial}*
ls: cannot access /dev/ttyUSB*: No such file or directory
ls: cannot access /dev/serial*: No such file or directory
crw-rw---- 1 root dialout 204, 64 Jan 31 23:30 /dev/ttyAMA0
crw-rw---- 1 root dialout   4, 64 Jan 31 23:24 /dev/ttyS0
Sorry that command should have been
ls -la /dev/{tty{ACM,AMA,S,USB},serial}*
Can you run it with the STM32 connected and then again with it disconnected. The entry that disappears when disconnected is the one you want.
Do you have anyother serial/usb devices connected?
either connected or disconnected I get the following:
pi@emonpi(ro):~$ ls -la /dev/{tty{ACM,AMA,S,USB},serial
ls: cannot access /dev/{ttyACM,serial: No such file or directory
ls: cannot access /dev/{ttyAMA,serial: No such file or directory
ls: cannot access /dev/{ttyS,serial: No such file or directory
ls: cannot access /dev/{ttyUSB,serial: No such file or directory
3rd time lucky maybe.
Sorry the last 2 characters got lost in transit when doing a copy and paste on the mobile.
I have corrected the typo now.
I appreciate your help!, Finally got it I had to use /dev/tty/ACM0.
thank you so much!!
Great! Sorry for the false starts, late night, tired and fiddly mobile are not a good combination.
For future readers, the command is basically a search for serial or USB devices with commonly used address prefixes eg “ttyAMA” “ttyACM” “ttyUSB” “ttyS” and “serial”.
would have returned something like (in this instance)
crw-rw---- 1 root dialout 204, 64 Jan 31 23:30 /dev/ttyACM0
with the STM32 attached and then
ls: cannot access /dev/ttyACM*: No such file or directory
in the first “connected” result the line
tells us there is a device using the /dev/ttyACM0 address and then in the second “disconnected” result that line no longer exists, but there is a new line showing no devices were found with an address prefix ttyACM
In this example '/dev/ttyS0andttyAMA0` are the Pi3’s 2 inbuilt UART serial ports, used by the bluetooth and GPIO.
