Hi Brian (@borpin),
The problem occurred again approximately 48 hrs ago. The log extract at the point where it stopped is as follows. This time the send failure is recorded.
2020-07-27 20:36:44,878 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1595846182.943008,15,314216,240.85,50,0,0,363,0,860136,58103,829449,0,-0.02,-0.02,0.6,0,10,300,300,300,0,0,-67],[1595846192.9315205,15,314217,240.84,49.99,0,0,363,0,860136,58103,829450,0,-0.03,-0.02,0.6,0,10,300,300,300,0,0,-67],[1595846203.0156538,15,314218,240.84,50,0,0,363,0,860136,58103,829451,0,-0.02,-0.02,0.6,0,10,300,300,300,0,0,-66]]&sentat=1595846204
2020-07-27 20:36:53,305 INFO MQTT Publishing: emonhub/rx/15/values 314219,240.70000000000002,49.99,0,0,575,0,860136,58103,829453,0,-0.02,-0.02,0.77,0,10,300,300,300,0,0,-66
2020-07-27 20:37:03,230 INFO MQTT Publishing: emonhub/rx/15/values 314220,240.68,50,0,0,542,0,860136,58103,829454,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-66
2020-07-27 20:37:13,256 INFO MQTT Publishing: emonhub/rx/15/values 314221,240.67000000000002,49.99,0,0,544,0,860136,58103,829456,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67
2020-07-27 20:37:16,911 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1595846213.0095506,15,314219,240.70000000000002,49.99,0,0,575,0,860136,58103,829453,0,-0.02,-0.02,0.77,0,10,300,300,300,0,0,-66],[1595846222.9820852,15,314220,240.68,50,0,0,542,0,860136,58103,829454,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-66],[1595846232.9721324,15,314221,240.67000000000002,49.99,0,0,544,0,860136,58103,829456,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67]]&sentat=1595846236
2020-07-27 20:37:23,187 INFO MQTT Publishing: emonhub/rx/15/values 314222,240.67000000000002,49.99,0,0,545,0,860136,58103,829457,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-68
2020-07-27 20:37:26,932 WARNING emoncmsorg emoncmsorg couldn't send to server: HTTPSConnectionPool(host='emoncms.org', port=443): Max retries exceeded with url: /input/bulk.json?apikey=1b41066907733c56b683845256988cf7 (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x75e7bb70>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
2020-07-27 20:37:26,933 WARNING emoncmsorg send failure: wanted 'ok' but got 'None'
2020-07-27 20:37:33,194 INFO MQTT Publishing: emonhub/rx/15/values 314223,240.67000000000002,50,0,0,543,0,860136,58103,829459,0,-0.03,-0.02,0.88,0,10,300,300,300,0,0,-67
2020-07-27 20:37:43,209 INFO MQTT Publishing: emonhub/rx/15/values 314224,240.68,50,0,0,541,0,860136,58103,829460,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67
2020-07-27 20:37:53,115 INFO MQTT Publishing: emonhub/rx/15/values 314225,240.68,49.99,0,0,540,0,860136,58103,829462,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67
2020-07-27 20:37:56,964 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1595846213.0095506,15,314219,240.70000000000002,49.99,0,0,575,0,860136,58103,829453,0,-0.02,-0.02,0.77,0,10,300,300,300,0,0,-66],[1595846222.9820852,15,314220,240.68,50,0,0,542,0,860136,58103,829454,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-66],[1595846232.9721324,15,314221,240.67000000000002,49.99,0,0,544,0,860136,58103,829456,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67],[1595846242.9700146,15,314222,240.67000000000002,49.99,0,0,545,0,860136,58103,829457,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-68],[1595846252.95848,15,314223,240.67000000000002,50,0,0,543,0,860136,58103,829459,0,-0.03,-0.02,0.88,0,10,300,300,300,0,0,-67],[1595846263.0282502,15,314224,240.68,50,0,0,541,0,860136,58103,829460,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67],[1595846273.0075676,15,314225,240.68,49.99,0,0,540,0,860136,58103,829462,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67]]&sentat=1595846276
2020-07-27 20:38:03,123 INFO MQTT Publishing: emonhub/rx/15/values 314226,240.68,50,0,0,540,0,860136,58103,829463,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67
2020-07-27 20:38:13,147 INFO MQTT Publishing: emonhub/rx/15/values 314227,240.67000000000002,50,0,0,538,0,860136,58103,829465,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67
2020-07-27 20:38:23,057 INFO MQTT Publishing: emonhub/rx/15/values 314228,240.65,49.99,0,0,538,0,860136,58103,829466,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67
2020-07-27 20:38:33,070 INFO MQTT Publishing: emonhub/rx/15/values 314229,240.66,50,0,0,537,0,860136,58103,829468,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-65
2020-07-27 20:38:43,266 INFO MQTT Publishing: emonhub/rx/15/values 314230,240.65,50,0,0,536,0,860136,58103,829469,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67
2020-07-27 20:38:53,173 INFO MQTT Publishing: emonhub/rx/15/values 314231,240.65,50,0,0,534,0,860136,58103,829471,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67
2020-07-27 20:39:03,161 INFO MQTT Publishing: emonhub/rx/15/values 314232,240.65,49.99,0,0,533,0,860136,58103,829472,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-66
2020-07-27 20:39:13,270 INFO MQTT Publishing: emonhub/rx/15/values 314233,240.66,50,0,0,532,0,860136,58103,829474,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67
2020-07-27 20:39:23,196 INFO MQTT Publishing: emonhub/rx/15/values 314234,240.65,50,0,0,531,0,860136,58103,829475,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-66
2020-07-27 20:39:33,217 INFO MQTT Publishing: emonhub/rx/15/values 314235,240.66,49.99,0,0,531,0,860136,58103,829477,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-66
2020-07-27 20:39:43,121 INFO MQTT Publishing: emonhub/rx/15/values 314236,240.66,50,0,0,530,0,860136,58103,829478,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-68
2020-07-27 20:39:53,286 INFO MQTT Publishing: emonhub/rx/15/values 314237,240.66,50,0,0,528,0,860136,58103,829480,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-66
2020-07-27 20:40:03,201 INFO MQTT Publishing: emonhub/rx/15/values 314238,240.65,49.99,0,0,527,0,860136,58103,829481,0,-0.03,-0.02,0.88,0,10,300,300,300,0,0,-66
2020-07-27 20:40:13,213 INFO MQTT Publishing: emonhub/rx/15/values 314239,240.67000000000002,50,0,0,527,0,860136,58103,829483,0,-0.02,-0.02,0.87,0,10,300,300,300,0,0,-71
2020-07-27 20:40:23,169 INFO MQTT Publishing: emonhub/rx/15/values 314240,240.66,50,0,0,528,0,860136,58103,829484,0,-0.02,-0.02,0.88,0,10,300,300,300,0,0,-67
As per previous instances, after restarting EmonHub, the posting to emoncms.org recommenced.
Other than restarting emonhub, I will leave things as they are in case you want to dig around a little.
