Hi.
The only mod I made to emoncms is the slight modification of the kW digits I made and discussed here MySolarBattery kW digits settings
I made some tests yesterday disabling the added services:
  • it seems that the CPU usage of emonhub does not increase.
  • then I added my ExternalMqtt service which was the latest added and CPU usage does not increase either. But this script do not push data to the emonpi mqtt broker, only to an external broker.
Do you think the problem is related to the fact that the 2 other python script services are publishing data to the emonpi mqtt broker like emonhub does (even if I do not know) ? I use aiomqtt module to do it with asyncio.
What could be the workaround ? pushing data with http requests ?
Thanks for your support !
