Hi Paul
Thanks for your reply. All the inputs and feeds are green, the times are always under 10s, but the data are wrong.
The realtime vis shows a similar lag. Is it normal for it to display nothing if you click “5 min” or “1 min”?
Jul 04 00:07:04 emonpi emonhub.py[16549]: 2018-07-04 00:07:04,954 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 24 18 16 42 106 96 32 40 32 48 4 24 64 83 15 224 33 0 0 9 32 (-93)
Jul 04 00:07:05 emonpi emonhub.py[16549]: 2018-07-04 00:07:05,066 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 20 22 168 48 9 32 32 64 4 2 100 24 64 83 15 224 33 0 0 9 32 (-99)
Jul 04 00:07:05 emonpi emonhub.py[16549]: 2018-07-04 00:07:05,174 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 29 64 128 13 70 1 125 3 148 192 130 73 14 0 68 192 26 136 2 80 (-92)
Jul 04 00:07:08 emonpi emonhub.py[16549]: 2018-07-04 00:07:08,208 DEBUG RFM2Pi 650 NEW FRAME : OK 5 120 0 0 0 120 0 180 92 196 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
Jul 04 00:07:08 emonpi emonhub.py[16549]: 2018-07-04 00:07:08,216 DEBUG RFM2Pi 650 Timestamp : 1530659228.21
Jul 04 00:07:08 emonpi emonhub.py[16549]: 2018-07-04 00:07:08,220 DEBUG RFM2Pi 650 From Node : 5
Jul 04 00:07:08 emonpi emonhub.py[16549]: 2018-07-04 00:07:08,224 DEBUG RFM2Pi 650 Values : [120, 0, 120, 237.32, 19.6, 0, 0, 0, 0, 0, 0]
Jul 04 00:07:08 emonpi emonhub.py[16549]: 2018-07-04 00:07:08,228 DEBUG RFM2Pi 650 Sent to channel(start)' : ToEmonCMS
Jul 04 00:07:08 emonpi emonhub.py[16549]: 2018-07-04 00:07:08,231 DEBUG RFM2Pi 650 Sent to channel(end)' : ToEmonCMS
Jul 04 00:07:08 emonpi emonhub.py[16549]: 2018-07-04 00:07:08,344 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 29 85 162 80 64 16 35 229 0 53 161 192 64 106 235 83 38 190 240 30 121 (-93)
Jul 04 00:07:09 emonpi emonhub.py[16549]: 2018-07-04 00:07:09,057 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 16 13 0 96 8 27 0 162 14 0 0 32 6 106 235 83 38 190 240 30 121 (-91)
Jul 04 00:07:09 emonpi emonhub.py[16549]: 2018-07-04 00:07:09,168 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 10 224 56 64 19 231 98 165 224 169 250 32 193 166 1 64 2 8 98 200 0 (-94)
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,344 DEBUG MQTT Publishing: emon/emonpi/power1 66
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,350 DEBUG MQTT Publishing: emon/emonpi/power2 0
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,355 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 66
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,357 DEBUG MQTT Publishing: emon/emonpi/vrms 234.62
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,359 DEBUG MQTT Publishing: emon/emonpi/t1 19.6
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,362 DEBUG MQTT Publishing: emon/emonpi/t2 0
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,365 DEBUG MQTT Publishing: emon/emonpi/t3 0
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,368 DEBUG MQTT Publishing: emon/emonpi/t4 0
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,370 DEBUG MQTT Publishing: emon/emonpi/t5 0
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,372 DEBUG MQTT Publishing: emon/emonpi/t6 0
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,377 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
Jul 04 00:07:12 emonpi emonhub.py[16549]: 2018-07-04 00:07:12,379 INFO MQTT Publishing: emonhub/rx/5/values 66,0,66,234.62,19.6,0,0,0,0,0,0
Jul 04 00:07:13 emonpi emonhub.py[16549]: 2018-07-04 00:07:13,197 DEBUG RFM2Pi 651 NEW FRAME : OK 5 121 0 0 0 121 0 167 92 196 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
Jul 04 00:07:13 emonpi emonhub.py[16549]: 2018-07-04 00:07:13,202 DEBUG RFM2Pi 651 Timestamp : 1530659233.2
Jul 04 00:07:13 emonpi emonhub.py[16549]: 2018-07-04 00:07:13,203 DEBUG RFM2Pi 651 From Node : 5
Jul 04 00:07:13 emonpi emonhub.py[16549]: 2018-07-04 00:07:13,204 DEBUG RFM2Pi 651 Values : [121, 0, 121, 237.19, 19.6, 0, 0, 0, 0, 0, 0]
Jul 04 00:07:13 emonpi emonhub.py[16549]: 2018-07-04 00:07:13,205 DEBUG RFM2Pi 651 Sent to channel(start)' : ToEmonCMS
Jul 04 00:07:13 emonpi emonhub.py[16549]: 2018-07-04 00:07:13,205 DEBUG RFM2Pi 651 Sent to channel(end)' : ToEmonCMS
I cannot begin to imagine why emonhub is logging a frame where the first value is 120 and then it publishes to MQTT the value 66!
Bruce
