# emonHP Level 3 Heat Pump Monitoring Bundle being installed
**URL:** <https://community.openenergymonitor.org/t/emonhp-level-3-heat-pump-monitoring-bundle-being-installed/24510>\
**Category:** Heatpump\
**Created:** [2 October 2023 22:32 UTC](https://community.openenergymonitor.org/t/emonhp-level-3-heat-pump-monitoring-bundle-being-installed/24510 "2023-10-02T22:32:22Z")\
**Showing post:** 4
**Post date:** [3 October 2023 07:24 UTC](https://community.openenergymonitor.org/t/emonhp-level-3-heat-pump-monitoring-bundle-being-installed/24510/4 "2023-10-03T07:24:22Z")
> [@LeiChat](#):
> and I presume you mean Open Energy Monitor, rather than Original Equipment Manufacture
Well this is the OEM forum 🤣
> [@LeiChat](#):
> A Home Assistant add-on that potentially captured the data locally from the heat pump monitoring hardware and also synchornised the data to emoncms/heatpumpmonitor would be awesome as it sounds like that might save running an additional Pi.
I agree - see this thread [Emoncms self contained docker container and HomeAssistant Addon](https://community.openenergymonitor.org/t/emoncms-self-contained-docker-container/23662) but definitely Beta ATM.
> [@LeiChat](#):
> My dislike of cloud services is more related to devices that don’t have a local store, which then do not catch up when an issue with the cloud service or connectivity is restored.
I’m not sure how the Valliant system works or if it catches up. I’m not sure the emonHP catches up either.
_[View the full topic](https://community.openenergymonitor.org/t/emonhp-level-3-heat-pump-monitoring-bundle-being-installed/24510)._
