Really sorry need to go. We will have to pick it up tomorrow.
I have a problem, RPi won’t let me log in. Is the user & password the same as emoncms.local?
I’ve tried changing password but still unable to log in.
Forget above, found obscure link to emonbase user & password so now I’m logged in
AFAIK
User is pi
Password is emonpi2016
The easiest way to set the timezone is to just type
sudo raspi-config
at the command prompt and use the menu system.
Thanks Paul that’s the ones I used. Changed the time to London so GLCD now showing correct time.
Do I need to log out of SSH, if so, how?
Tanks for all your help Brian now sorted the time issue with GLCD
You can just type
exit
Thanks Paul, I’d forgotten about the config tool.
