Hi Robert
Thanks a lot for your extended support.
I am running your sketch (with #define RF69_COMPAT 1 and #define DEBUG enabled) and I can see all RF nodes (emonth devices (nodeid 23, 24, 25) and emonbase (nodeid 5)) in my system EXCEPT emontx.
Here is serial debug log :
emonGLCD Debugger
openenergymonitor.org
RF received - Node 24
Val1=167, Val2=0, Val3=660, Val4=26, Val5=1, Val6=0
RF received - Node 23
Val1=186, Val2=0, Val3=596, Val4=28, Val5=1, Val6=0
RF received - Node 5
Val1=3584, Val2=51
RF received - Node 25
Val1=189, Val2=0, Val3=567, Val4=28, Val5=1, Val6=0
Val1=166, Val2=0, Val3=657, Val4=26, Val5=1, Val6=0
Val1=188, Val2=0, Val3=567, Val4=28, Val5=1, Val6=0
Instead I confirm that emonTX and emonBase are communicating correctly. Sort of radio incompatibility between emonTX and emonGLCD.
Do you suggest to flash latest firmware onto emonTX ?
