# EmonGLCD does not read time nor Power
**URL:** <https://community.openenergymonitor.org/t/emonglcd-does-not-read-time-nor-power/5002>\
**Category:** Hardware\
**Created:** [4 September 2017 14:18 UTC](https://community.openenergymonitor.org/t/emonglcd-does-not-read-time-nor-power/5002 "2017-09-04T14:18:03Z")\
**Showing post:** 31
**Post date:** [4 November 2018 00:28 UTC](https://community.openenergymonitor.org/t/emonglcd-does-not-read-time-nor-power/5002/31 "2018-11-04T00:28:08Z")
You could try compiling the emonGLCD sketch with an earlier version JeeLib.
The current emonPi, emonTH and emonTH sketches are all compiled with outdated JeeLib
> <https://github.com/openenergymonitor/emonpi/blob/master/firmware/platformio.ini#L38-L38>
> <https://github.com/openenergymonitor/emontx3/blob/master/firmware/platformio.ini#L32-L32>
> <https://github.com/openenergymonitor/emonth2/blob/master/firmware/platformio.ini#L27-L27>
When the emonPi firmware is compiled with a later JeeLib it fails to receive emonTx packets (Or least that used to be the case, see [Emon TXs not updating after Emonpi update - #12 by glyn.hudson](https://community.openenergymonitor.org/t/emon-txs-not-updating-after-emonpi-update/2233/12))
[edit - also see “[emonTx Node Communicates to one RFM69Pi, but not another](https://community.openenergymonitor.org/t/emontx-node-communicates-to-one-rfm69pi-but-not-another/7771)” for a similar issue with a RFM69Pi recompiled with a later JeeLib, and again here “[Recompiling RFM69Pi firmware - #6 by adpeace](https://community.openenergymonitor.org/t/recompiling-rfm69pi-firmware/2618/6)”]
_[View the full topic](https://community.openenergymonitor.org/t/emonglcd-does-not-read-time-nor-power/5002)._
