@glyn.hudson
The house is on 3 phase.
The emonEVSE charger is 3 phase which calculates energy assuming all phases are being used.
Is there a simple approximation to use to indicate energy when a single phase EV is being charged - eg: divide by 3
Thanks for your guidance
Hi John.
I have an emonEVSE 3 phase in a 1 phase house and 1 phase EV.
My EVSE supply circuit has a physical check meter in-line.
You are quite right - the energy reading in the EVSE web interface shows 3kWh for every 1kWh recorded in the check meter.
