This new look for My solar is terrible. Can’t read anything on the tablet unless you are holding it use to use it as a display if this is the new way and we can’t go back I will need to find a better service. This has gone down hill fast. Been using this for over 10 years also. Sooo Sad. Why break a good thing at least let us pick and go back to the old look.
Hello @kendive we’re discussing an option to increase text sizes of those app values/labels here Emoncms v12 release, testing feedback welcome! now on emoncms.org - #7 by Umski I was undecided on whether the text was too small when making this change so I am open to refining this to take into account feedback from everyone using it. We’ve had positive feedback from a number of users about these changes as well so it’s a balance to strike. The reason for this change was that every app implemented it’s own set of styles and were based on a big mix of legacy and newer css code, there was little consistency. Im trying to clean the code up to make it more maintainable and consistent for the longer term.
Would be nice to just let us setup the old style one. There is no reason you can’t do that just put it back in the list. This new setup is awful and looking for other options now. I can probably use the same CT’s also. Just pull the main board and switch to a ras pi 5.
To be honest I think I can get this closer to the original, maybe I did change it a bit too much!
I’ve been focused on the MyElectricFlow and MyHeatpump apps and didnt spend that much time on the old MySolar app. Will have something to share soon.
I’ve made a few changes that brings the MySolarPV app back closer to the original while maintaining 99% of the new common css, upgraded chart library etc / maintainability benefit, and I agree it’s better than it was! This is live on emoncms.org.
Original (left), New revised (right):
There are a couple of other improvements to the latest version of the MySolarPV app:
When configured with use_kwh, solar_kwh and import_kwh feeds zooming out on the power view now uses these kWh feeds to calculate accurate totals over very long timescales. Previously using only the power feeds when zooming out the direct/export/from grid percentages and totals could become in significant error.
The daily view now shows the totals for the whole window rather than just the hovered over day. The values for a hovered over day is shown in a tooltip instead:
Looks alot better. Anyway to make those top numbers bigger?
