When selecting Dashboards on the top tabs, the LHS menu used to change to show ‘Configurations’ which you;d click to see all the dashboards you had.
Now however, that only happens if you are already looking at Feeds and Inputs. If you are looking at Grahps, the LHS menu is unchanged.
Hello @JustPlaying I dont quite understand what you mean? This is what I see when looking at the dashboards menu:
for me at my account at openems.org,
if I am in Feeds or Input menu - then clicking Dashboards I see what you see
*if I am in Graphs, and click 'Dashboards; - the left hand menu doesn’t show ‘Dashboards’ , configurations: it is ‘stuck’ on the Graphs sub-menu
Ah I see what you mean, you need to publish the dashboards from the dashboard configuration page for them to list in the dashboard menu. I think that has been like that for a while. They dont need to be public but they do need to be privately published .. slightly confusing terminology and setting really..
That’s not quite it. The issue is the left hand menu behaviour: what shows depends on what page you are looking at when you click ‘Dashboard’ menu at top.
The correct left-hand menu shows when starting in Feeds or Inputs page. But not when starting from Graphs page. As per the image above: when you see in that case, is still the Graphs sub-menu page. Which is wrong.
Unless I’m missing something…
