Community
OpenEnergyMonitor
Community
Emoncms V10.2.4 release
Recent changes to emoncms master and associated modules have now been merged to stable and are now available via emonPi/emonbase update.
This release is marked as v10.2.4: https://github.com/emoncms/emoncms/releases/tag/10.2.4
Thankyou to everyone who contributed to development associated with this release and associated modules.
To update: run emonPi/emonbase update from the Admin tab of emoncms.
CHANGE LOG SUMMARY
Note that a number of th modules were available on stable prior to this post, if you have run the updater recently you may already have these changes.
Emoncms core 10.2.4:
*BREAKING CHANGE: The new MQTT topic filter provides better support for a larger variety of topic formats but it can result in broken inputs which will need re-mapping. See Emoncms v10.2.1 New MQTT Topic Filter Issue.
Dashboard module v2.0.8
  • Option to specify number of blocks in the battery widget, thanks to @thib66
  • Option to scale value in feedvalue widget
  • Optimisations to widgets to reduce memory use
App module v2.1.6
  • MySolarPV and Battery app
  • Improvements to the Octopus Agile app thanks @stuartpittaway
  • Add Licence file and composer changes thanks to @reedy
Device module v2.0.6
  • API to clean unused devices /emoncms/device/clean
Backup Module v2.2.4
  • lmproved USB drive support in USB import script
DemandShaper Module v1.2.6
  • Support for negative prices in forecast chart, thanks to @jpalo
  • Add licence file and composer changes thanks to @reedy
  • Fix Run period getting cleared in time controltype, thanks to @jpalo
  • Changes to remote octopus agile cache API
  • Smart plug simulator
WiFi Module v2.0.3
  • Fix handling of special characters
  • Provide better feedback on WiFi configuration process
  • Fix WiFi restart command to correctly reconfigure wpa_supplicant
Post Process Module v2.1.4
  • Battery simulator to use with MySolarPVBattery app
  • improved formula post process thanks to @alexandrecuer
The total number of open bugs on all emoncms repositories including modules is now 51 and can be tracked here: https://github.com/issues?q=is%3Aopen+is%3Aissue+user%3Aemoncms+label%3Abug
