Hello @Andreas_Munzenmaier looks like there’s a new issue associated with the units field for the graph. I’ve commented out the % unit for now to fix the issue temporarily. I’ve created an issue to improve unit support here: Visualisation units not encoded properly · Issue #1564 · emoncms/emoncms · GitHub
Thanx works now
Since yesterday the iOS app does not show dashboard
Hello @Andreas_Munzenmaier could you try again now and reload the page?
Now it works again thanx
The graphs that are usually available from the feeds page are now all blank, I think since the upgrade to 10.2.1, which I did by
git pull
from
/var/www/emoncms
and then updating the database from the admin page of the web interface.
Have I missed a step?
Hi Jeff,
Have you tried clearing your browser cache?
Hello @jeff, to add to Bills suggestion, you need to update all optional modules as well, such as the graph module and dashboards.
Assuming that you have a custom installation there, the steps are:
cd /var/www/emoncms/Modules/graph
git pull
cd /var/www/emoncms/Modules/dashboard
git pull
If you have a standard emonSD or EmonScripts based installation, then it is best to use the update facility available from the Emoncms admin page.
D’Oh!
Forgot about the modules. :frowning_face:
Yup. Thanks. That did the trick. I hadn’t upgraded it for such a long time, I forgot how.
