borpin
(Brian Orpin)
1
Might this be a breaking change?
I dont think its a breaking change, but may cause new inputs to appear for some users posting MQTT data with extended topic strings. Whereas previously these inputs would have been conflated together into a non functional input.
borpin
(Brian Orpin)
3
@TrystanLea It is…
Pre update
Post update
Bugger.
The old mechanism simply discarded the topics below a certain level!
[edit]
These topics
are no longer received…
Hello @borpin
Not so fast then!
A quick script to test here suggests that those topics should work:
import time
import paho.mqtt.client as mqtt
mqttc = mqtt.Client("topic_test")
mqttc.username_pw_set("emonpi", "emonpimqtt2016")
mqttc.connect("192.168.1.64", 1883, 60)
mqttc.loop_start()
while 1:
mqttc.publish("emon/xiaomi4c:65:a8:d8:de:98/battery",3.3,2)
mqttc.publish("emon/xiaomi4c:65:a8:d8:de:98/humidity",56.6,2)
mqttc.publish("emon/xiaomi4c:65:a8:d8:de:98/temperature",19.6,2)
print "."
time.sleep(10)
mqttc.loop_stop()
mqttc.disconnect()
I wonder what the difference is between your system and mine?
borpin
(Brian Orpin)
5
Never make 2 changes at once - Apologies, @TrystanLea entirely my fault. this one.
borpin
(Brian Orpin)
6
But the additional _state in the Input name is a breaking change. I think the additional topic levels must have been discarded before.
Good to hear its working!
yes i think that was the case. If you would have had two similar topics one /state and another /value they would have written on top of each other… are you happy with the steps required to remap this new input?
borpin
(Brian Orpin)
8
Yes but it should be highlighted as a breaking change. In my case there was only one topic so it was not overwritten (though that had happened before).
The idea is sound but I think should have had an attached setting to enable/disable it to avoid it being a breaking change.
