I updated my standard emoncms version recently (emonpi + 3x EmonTx V3) using the web interface “emoncms update” button . It now reads as “low-write 9.8.31 | 2018.06.21”.
If I interpret the log correctly, it says that the update went OK
BUT
Only the graphs are appearing on my dashboards, the feed values and the dials are missing and when I try and edit them back in, they do not appear to be available any more.
Otherwise the system seems to be working normally.
I’m not at all sure how to start looking for the solution to this problem, so any pointers would be greatly appreciated.
Maybe I should clarify one point. When I try and edit the dashboard, there are no options to add a feed value or a dial to the dashboard. In fact there are no options to add items and I cannot select an item - even a graph or label that is already there.
Just to be absolutely 100% sure could you open up a Firefox ‘Private Browser’ window (Ctrl + Shift + P), as that doesn’t cache temporary files.
If they still don’t show, please then press F12 to see the browser console, and see if any errors are being reported.
