I have copied the CSV data below. Now I do not know why it plots it a bunch of times. I have proven to myself I only send it once. This is another problem I mentioned earlier that I still need to figure out.
Now about what you said on start time of 00:00 UTC I had changed it to 01:00 UTC because for some reason which I now forget (this has been a problem for a long time and much time was spent for example in the beginning I assumed it was my ESP board) and EmonPi still showed it on the graph as 19:00 from the day before.
So setting it to either 00:00 local or 01:00 local both result in a timestamp of 19:00?
Anyway, I will try 23:59 local and set EmonPi for hourly feed.
Some more info which may help. I am running this on a Pi3.
And, I work at a college and have a setup here running on a Pi4. And I have this same issue at the college.
1673910900, null
1673911800, null
1673912700, null
1673913600, 1
1673914500, 1
1673915400, 1
1673916300, 1
1673917200, 1
1673918100, 1
1673919000, 1
1673919900, 1
1673920800, 1
1673921700, 1
1673922600, 1
1673923500, 1
1673924400, 1
1673925300, 1
1673926200, 1
1673927100, 1
1673928000, 1
1673928900, 1
1673929800, 1
1673930700, 1
1673931600, 1
1673932500, 1
1673933400, 1
1673934300, 1
1673935200, 1
1673936100, 1
1673937000, 1
1673937900, 1
1673938800, 1
1673939700, 1
1673940600, 1
1673941500, 1
1673942400, 1
1673943300, 1
1673944200, 1
1673945100, 1
1673946000, 1
1673946900, 1
1673947800, 1
1673948700, 1
1673949600, 1
1673950500, 1
1673951400, 1
1673952300, 1
1673953200, 1
1673954100, 1
1673955000, 1
1673955900, 1
1673956800, 1
1673957700, 1
1673958600, 1
1673959500, 1
1673960400, 1
1673961300, 1
1673962200, 1
1673963100, 1
1673964000, 1
1673964900, 1
1673965800, 1
1673966700, 1
1673967600, 1
1673968500, 1
1673969400, 1
1673970300, 1
1673971200, 1
1673972100, 1
1673973000, 1
1673973900, 1
1673974800, 1
1673975700, 1
1673976600, 1
1673977500, 1
1673978400, 1
1673979300, 1
1673980200, 1
1673981100, 1
1673982000, 1
1673982900, 1
1673983800, 1
1673984700, 1
1673985600, 1
1673986500, 1
1673987400, 1
1673988300, 1
1673989200, 1
1673990100, 1
1673991000, 1
1673991900, 1
1673992800, 1
1673993700, 1
1673994600, 1
1673995500, 1
1673996400, 1
1673997300, 1
1673998200, 1
1673999100, 1
1674000000, 1
1674000900, null
1674001800, null
1674002700, null
