A security feature was introduced to ensure that the ‘administration’ menu is only accessible during a logged-in session. whilst the ‘My Account’ remains accessible under wider circumstances.
If the API keys are sensitive, wouldn’t it make sense to include them in the most secure location?
The permissions and ownerships on the php datadir’s look fine.
The logs you’ve posted just now look like they highlight another, but most probably an unrelated issue. Where is the data coming from?
Those messages tell us the data is arriving in the wrong format or has errors.
But the inputs seem to be updating, some, if not all the time, so some data is getting through.
Inputs not updating would not cause the feeds to not be found or the processlists to not populate, so probably unrelated.
I’m not sure if starting afresh may prove easier than trying to fix this install, have you considered starting again on the remote server? Is the emonPi still working ok?
(I haven’t had much time for posting on the forum, which is why I hadn’t answered your PM, support is best kept out on the forum)
Is the settings.php pointing at the correct location for the datadir’s?
The file size and last update times of the files in the datadir’s you’ve shown us vary, suggesting the feeds did not all stop together or they are remains from an earlier install attempt, what happens with the first feed (feedid 1) you try to create after a fresh install? do you get any error messages like “unable to create feed” or “unable to save processlist” etc etc?
I’m afraid I’m running out of idea’s, which guide are you following and did you make any changes to the instruction at all?
Do AWS have a helpdesk? maybe it’s a quirk with their setup,
i reinstall emoncms on remote server and datadir its the same
im ussing this guide
openenergymonitor/emonhub/blob/emon-pi/configuration.md#c-emoncmsorg
If im reciving data from my emonpi inputs on remote emoncms inputs its because at some point the remote server is receiving data from emonpi , in my opinion the data are getting in emoncms remote AWS , the problem is some inside config on emoncms remote , because for some reason the data cant by displayed or proceced on Feeds , maybe im wrong
hi
i bought the shield only , but in my country the customs are very slow , soo waiting for it
anyway im working on a one part , only the shield with micro inside , to reduce cost and compability problems ,
what problems are you experimented>
