I’ve merged the latest master branch into stable, including the following changes:
- Updated rpi model list @gablau
- Fix tests and jquery update @reedy
- Translation update @thib66
- Use settings.php graph path
- Change feed module html view path to feed/view
- Fix delete modal layout @emrysr
- Fix missing filtering in input name and nodeid’s causing duplicating inputs
- Seperate out svg_icons @emrysr
- Username auto focus on login @emrysr
- Fix missing histogram engine methods @borpin
- Datatype added to feed list tooltips @emrysr
- Fix missing feed processlist in feed list @emrysr
- Cookie caching of input list state @emrysr
- Hardcoded datapoint limit settable in settings.php
- Logrotate logging fix, thanks @pb66
- Use emoncms setup sidebar menu for all setup related modules
- Fix embed view
https://github.com/emoncms/emoncms/releases/tag/10.1.3
I’ve also updated the following modules with related changes (including master → stable merges and version updates where applicable): wifi, graph, device, dashboard, config, backup, app, postprocess, sync, remoteaccess-client.
To update: run emonPi/emonbase update from the Admin tab of emoncms.
Related to recent issues highlighted in the forums:
The My Electric and My Solar app embed bug is now fixed
Issue with full menu system being shown for public dashboards is now fixed, with only the related public part of the menu being shown:
I’ve also moved the menu items that were under the cog on the right hand side to the main setup menu. I think it works better as all of these items are in one place, I found myself jumping from one menu to the other trying to find what I was looking for:
gilaraujo
(Gil Araújo)
3
Greetings. Does this also apply to emonpi running locally
Tried running the update but seems still on " Powered by OpenEnergyMonitor.org | [low-write 10.1.2]"
Is any special action require to update local installs?
TrystanLea
(Trystan Lea)
Split this topic
4
A post was split to a new topic: Dashboard background
Neil
(Neil Hastings)
5
Hello @TrystanLea,
Before I update can you please clarify exactly what should be done to update. The options do not match:
Should I update ‘emoncms’ and then ‘emonpi’ firmware, or 'full update?
Thanks and best wishes,
Neil
@gilaraujo @Neil yes, select the relevant firmware in the firmware only section and then click “Full Update” at the top - as shown in @Neil’s screenshot . The update will then run through the update for all components.
gilaraujo
(Gil Araújo)
7
I think i see why update is failing. By changing the smtp settings on settings.php it produces an Abort on update.
Emoncms update started
Emoncms update script V1.3 (26th March 2019)
- branch stable → FETCH_HEAD
error: Your local changes to the following files would be overwritten by merge:
default.emonpi.settings.php
default.settings.php
Please commit your changes or stash them before you merge.
Aborting
Updating a0c672e4…28c47cfd
gilaraujo
(Gil Araújo)
8
Please ignore above
While trying to fix send email i played with the default email on
Which i shouldnt have! so might serve as a warning for failed updates in future.
Reverted changes to default email to root@localhost on them two files and update worked however throwing an error.
NEW default settings.php md5: 59e80f731935867f5f93753d49c0fe86
Update required to settings.php...
**ERROR: unable to autoupdate settings.php since user changes are present, manual review required**
What are the best Practice in this case. Revert settings.php to default, then apply smtp settings again?
Or is perfectly ok to allow update in that way?
I think in this case there are no important settings updates for settings.php so you can ignore that error. We are working towards a better solution to the way the settings are handled that should improve this in future.
Neil
(Neil Hastings)
10
Hi @TrystanLea,
I did the update, all looks OK except emoncms is now v10.1.4-beta. I don’t mind the ‘beta’, I just wondered why it’s 10.1.4.
Server Information
Server Information
Services
emonhub :- Active Running
emoncms_mqtt :- Active Running
feedwriter :- Active Running - sleep 60s 66 feed points pending write
service-runner :- Active Running
emonPiLCD :- Active Running
redis-server :- Active Running
mosquitto :- Active Running
Emoncms
Version :- low-write 10.1.4-beta
Modules :- Administration | App v2.0.2 | Backup v1.1.6 | EmonHub Config v2.0.3 | Dashboard v2.0.4 | Device v2.0.1 | EventProcesses | Feed | Graph v2.0.2 | Input | Postprocess v2.1.0 | CoreProcess | remoteaccess | Schedule | Network Setup v1.0.0 | sync | Time | User | Visualisation | WiFi v2.0.1
Git :-
Server
OS :- Linux 4.14.71-v7+
Host :- emonpi | emonpi | (192.168.1.11)
Date :- 2019-08-12 10:06:45 EDT
Uptime :- 10:06:45 up 2 days, 19:59, 1 user, load average: 0.45, 0.69, 0.41
Memory
RAM :- Used: 29.36%
Total :- 976.74 MB
Used :- 286.77 MB
Free :- 689.97 MB
Swap :- Used: 0.00%
Total :- 100 MB
Used :- 0 B
Free :- 100 MB
Disk
/ :- Used: 42.49%
Total :- 3.81 GB
Used :- 1.62 GB
Free :- 2.01 GB
/boot :- Used: 51.72%
Total :- 42.52 MB
Used :- 21.99 MB
Free :- 20.53 MB
/home/pi/data :- Used: 1.78%
Total :- 10.32 GB
Used :- 187.82 MB
Free :- 9.61 GB
/mnt/usbdrive :- Used: 0.34%
Total :- 28.97 GB
Used :- 99.45 MB
Free :- 27.38 GB
HTTP
Server :- Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
Version :- 5.5.5-10.1.23-MariaDB-9+deb9u1
Host :- localhost:6379 (127.0.0.1)
Date :- 2019-08-12 10:06:45 (UTC -04:00)
Stats :- Uptime: 245203 Threads: 3 Questions: 212415 Slow queries: 0 Opens: 45 Flush tables: 1 Open tables: 39 Queries per second avg: 0.866
Redis
Version :- 3.2.6
Size :- 236 keys (783.65K)
Uptime :- 2 days
MQTT Server
Version :- Mosquitto 1.4.10
Host :- localhost:1883 (127.0.0.1)
PHP
Version :- 7.0.30-0+deb9u1 (Zend Version 3.0.0)
Modules :- apache2handler | calendar v7.0.30-0+deb9u1 | Core v7.0.30-0+deb9u1 | ctype v7.0.30-0+deb9u1 | curl v7.0.30-0+deb9u1 | date v7.0.30-0+deb9u1 | dom v20031129 | exif v7.0.30-0+deb9u1 | fileinfo v1.0.5 | filter v7.0.30-0+deb9u1 | ftp v7.0.30-0+deb9u1 | gd v7.0.30-0+deb9u1 | gettext v7.0.30-0+deb9u1 | hash v1.0 | iconv v7.0.30-0+deb9u1 | igbinary v2.0.1 | json v1.4.0 | libxml v7.0.30-0+deb9u1 | mbstring v7.0.30-0+deb9u1 | mcrypt v7.0.30-0+deb9u1 | mosquitto v0.4.0 | mysqli v7.0.30-0+deb9u1 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $ | openssl v7.0.30-0+deb9u1 | pcre v7.0.30-0+deb9u1 | PDO v7.0.30-0+deb9u1 | pdo_mysql v7.0.30-0+deb9u1 | Phar v2.0.2 | posix v7.0.30-0+deb9u1 | readline v7.0.30-0+deb9u1 | redis v4.1.1 | Reflection v7.0.30-0+deb9u1 | session v7.0.30-0+deb9u1 | shmop v7.0.30-0+deb9u1 | SimpleXML v7.0.30-0+deb9u1 | sockets v7.0.30-0+deb9u1 | SPL v7.0.30-0+deb9u1 | standard v7.0.30-0+deb9u1 | sysvmsg v7.0.30-0+deb9u1 | sysvsem v7.0.30-0+deb9u1 | sysvshm v7.0.30-0+deb9u1 | tokenizer v7.0.30-0+deb9u1 | wddx v7.0.30-0+deb9u1 | xml v7.0.30-0+deb9u1 | xmlreader v7.0.30-0+deb9u1 | xmlwriter v7.0.30-0+deb9u1 | xsl v7.0.30-0+deb9u1 | Zend OPcache v7.0.30-0+deb9u1 | zlib v7.0.30-0+deb9u1
Pi
Model :- Raspberry Pi 3 Model B+ Rev 1.3 - 1GB (Sony UK)
SoC :- Broadcom BCM2835
Serial num. :- 5ABE4EF9
Temperature :- 53.15°C - 52.6°C
emonpiRelease :- emonSD-30Oct18
File-system :- read-write
Client Information
Client Information
HTTP
Browser :- Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_5) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/12.1.1 Safari/605.1.15
Language :- en-us
Window
Screen
Resolution :- 1680 x 1050
Thanks,
That’s because you are running the master branch rather than stable, though right at this time they are both exactly the same apart from the version file…
You are welcome to stay on the master branch, the master branch is updated more regularly but may be less stable…
