Following a power cut this weekend I have lost my Raspberry Pi emoncms data. Courrupted SD Card.
I have put a clean install of Emoncms 10.2.0 on a new cardand it is running OK I cannot recover the data form the old card using the back up function. It says USB not found. Any ideas. Can I manualy copy the old files across and which are they.
Also on the new install the SD expasion command doesn’t work. Again any ideas.
Thanks Brian I used the backup utility on emoncms. I downloaded a clean emonSD-17Oct19 version. I tried an fsck which cleaned up a lot of errors but I could not get the old disk to boot. I did notice though the corrupted SD card is lableled sdc1, sdc2, and sdc3.
Hi Brian I used the post and it worked a treat. Thank you. I had to delet Mass-storage in the script but back on track. Many thanks to other contributors.
I am still a little unclear whether the new sd card has been expanded any ideas.
