it’s a few days that I am pushing on an regular bases onto emoncms.org
Things are usually working fine, but sometimes I am receiving a Connenction Refused error.
This mean that the connection with emoncms.org is well established (no timeout or connection issues) but the server itself drops the established connection.
The calls are done through a Python client running on a Raspberry.
Here you can find a sample of the errors:
gen 29 17:15:25 raspberrypi start_hpsu_medium.sh[24623]: return request(‘get’, url, **kwargs)
gen 29 17:15:25 raspberrypi start_hpsu_medium.sh[24623]: File “/usr/lib/python3/dist-packages/requests/api.py”, line 49, in request
gen 29 17:15:25 raspberrypi start_hpsu_medium.sh[24623]: return session.request(method=method, url=url, **kwargs)
gen 29 17:15:25 raspberrypi start_hpsu_medium.sh[24623]: File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 457, in request
gen 29 17:15:25 raspberrypi start_hpsu_medium.sh[24623]: resp = self.send(prep, **send_kwargs)
gen 29 17:15:25 raspberrypi start_hpsu_medium.sh[24623]: File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 569, in send
gen 29 17:15:25 raspberrypi start_hpsu_medium.sh[24623]: r = adapter.send(request, **kwargs)
gen 29 17:15:25 raspberrypi start_hpsu_medium.sh[24623]: File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 407, in send
gen 29 17:15:25 raspberrypi start_hpsu_medium.sh[24623]: raise ConnectionError(err, request=request)
gen 29 17:15:25 raspberrypi start_hpsu_medium.sh[24623]: requests.exceptions.ConnectionError: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
I am pushing a set of 17 data pushed with a single emoncms.org API call every 10 seconds.
Is there any known limitations ?
I found only this statement:
https://emoncms.org/site/usage
Thanks in advance for the support !
