When you send the data from a page in your web browser, in the format you were trying using the test message from Input API Help, you are checking and testing the Input, and if the same numbers in the test string appear on the Inputs page itself (not the Inputs API Help page), the test was passed.
Remember I only know what you write here, I don’t know what is inside your head. Maybe you need to explain what you want to achieve?
You must arrange for the “random variable generator in python” to send the data in the same format and to the same address as the test message shown on the API Help page.
I am talking about the MariaDB server database. I am not getting Feed values in the Database. It shows NULL values in emoncms database in the input table.
You’re not using the Feeds (built-in databases) then?
I’ve never looked into using any other database such as MariaDB. How are you sending the data there? Because normally, the database is either PHPFINA or PHPTIMESERIES, which you select when you set up the Feed; and that’s because with large amounts of data, other databases, e.g. MariaDB or MySQL, become extremely slow.
Have you actually read the Guide? Try looking in there - you are looking in emonCMS for Graphs and Dashboards. It’s not reasonable to expect me to rewrite the Guide here.
I came to know that from guide, mysql databases stored with the data framework. And all the feed recorded datas are stored in PHPFina and PHPTimeSeries databses.
Now, how can i see the feed recorded data in PHPFina and PHPTimeSeries databses?
I am extremely sorry I am new to the EMONCMS platform. I am learning day by day.
I don’t know Python. All the information about Feeds is in - would you believe - the ‘Learn’ section, under Electricity Monitoring (of course), Timeseries. The source code is in PHP, it should not be very difficult to transcribe it into Python.
Hello @vasanthk239 the standard way to view the data stored in PHPFina and PHPTimeseries is via the emoncms interface of course, but if you want to access the data directly at a low level using python the code in the python based emoncms data downloader and conversion to csv tool might be useful here: https://github.com/emoncms/usefulscripts/blob/master/backup_py/convert_to_csv.py
